everyone post your lowered trucks measurements here!
this is to help people like me who bought a truck already lowered and want to know exactly how much it was lowered.
measure from the ground up through the middle of your wheel until the the tape measure hits the center of you fender lip. (this should be roughly the highest point of the fender lip curve, but your measuring from the bottom.) also see attached picture if you dont know exactly how much your truck was dropped or dont know tire sizes then dont post, id like to get accurate measurements for us to compare to. this will also help the guys with airbags to determine what their ride height is etc. for example my measurements were 26.5" front 29.5" rear on 205/75/15s and 235/75/15s and im an unsure of what mines dropped (im guessing 5.5/5") ![]() |
Just here to help
![]() Join Date: Jan 2002
tires are 275r15 the measurements are 29.5 rear and 29 at the front.Hope that helps but i am not sure of how mine was dropped either.It was this way when i got it
TTT
sorry purple, our measurements are useless without at least one person knowing their exact drop and measurement.
not one person have a truck dropped 2/4 3/5 4/6 or anything that can measure? please help a fellow 67-72 owner out. |
Señor Member
Gang, you all need to be measuring from a fixed point... either from the lip to the center of the hub or the lip to the bottom edge of the wheel (then we'll need to know what diameter wheel you have). Otherwise there's no real way to correlate the various measurements. Even if we know tire size, 3 brands of the EXACT same tire size will all be different heights. So... go back and re-measure :-)
Kenneth
Señor Member
BTW, here are my measurements as described in my previous post. (Yuck... that was supposed to be more legible. It reads 10" front and rear.)
Kenneth
bumping this one to the top...
chevelito
sup kenneth,
your truck is lookin sweeter and sweeter. Now i'm really deciding wether to keep the stepside bed. jay
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
2/4 drop 255/70-15s
29.5 front 31.5 rear
1971 Cheyenne Super Soon to be converted to '68 front clip. Efland, NC |
#9 | |
Re: 2/4 drop 255/70-15s
ill bump this up for the last time to get some measurements from others. |
my front meas. 29-5 but back i cant do no bed
#11 | |
Señor Member
(phew...) Kenneth
#12 | |
#13 |
Out of the carpool lane.
Mines 15" all the way around. 4" drop springs in rear, 2" spindles, 2" springs
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#14 |
Four Wheeler
Mine measures 16½" from wheel center to fender lip, all the way around. I know it's been lowered, but I'm curious as to how much? Anyone have measurements for a stock ride-height C10?
'84 K20 4x4 350 V8 - Weiand intake - Headers - 4" Tuff Country lift - 35x12.50 ProComp M/Ts on 15x10s |
#15 | |
thanks for posting guys, the more measurements the more accurate of an average i/we can get. |
#16 |
Four Wheeler
You've got a point there, Blake! LOL!
Thanks for making the obvious more clear.... I'm at work right now, so I'm in my "unproductive mindset" since it's Saturday!
#17 |
Slowly getting CRSS...
ttt
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
#18 |
now that i got my truck here, from the center of the hub to the lip of the fender is front: 17.5 rear: 18 Now i have a BB riding on 350 springs, and ive done a 2.5'' block drop out back which makes me wonder...
#19 |
![]() Join Date: Jan 2001
Location: Katy, TX...but the love of my life resides in Dublin,OH.
i measured both trucks....
my stock 68 and my heated spring lowered 71...I now have concrete evidence of one thing that I was suspicous of.
The bed on the 68 is tweaked... visible from a distance behind the truck. measured from the center of the center cap to the lip 68 front 19" 19" rear 18.5" 19.75" 71 front 16" 15.75" rear 17.5" 17.5" |
#20 |
ok i just went out w/ a straight edge and measured it right.
Front 18 17 17.5 17.5 Rear The driverside front corner sits 1'' higher that the passenger side. This is also the corner that has about -1 degree of camber. It is also the side of the truck that lifts under hard acceleration. Im going to a chassis dyno to get the rear wheel figures on the motor. Could the torque of the motor tweaked something?
#21 |
Señor Member
For those of you finding the corners not being the same height (like an inch or less difference from right to left), that's actually pretty normal. I've lowered several hundred trucks in my life and it is not uncommon to see slight variations... and while it doesn't look bad on a stock height truck, the problem exacerbates itself when you lower a vehicle because the 1" difference is now a larger part of the total height (as in 1" diff. on the 19" stock height, and now is 1" on the 13" lowered height). Typically you can solve this kind of issue with small shims in the rear. The front is a little trickier... but also less common to see a difference from side to side.
[ramble off] ![]() Kenneth
#22 |
Back from the Dead
OK, I went out and measured mine. Looks like the front is 15" and the rear is 17". Correct me if I'm wrong please, but wouldn't that be something like a 4/2 drop?
Kenny
The only Carb that matters to me is the one under my hood! Salem, Oregon |
#23 |
Just here to help
All i measured was the driver side................16.75 front.........17 rear.Can someone tell me about what drop that would be?Thanx..........................James
#24 |
was wondering if anybody has just put in new stock springs and could possibly measure from the center of the center cap to the lip of the fender.
