Old 09-21-2006, 12:42 AM   #1
shifty
Questionable
shifty's Avatar
How in the heck? Inner firewall padding removal.
Ok...so the cardboard-backed sound deadener sheet that's on the firewall....how does a guy go about getting the rubber plugs out to pull that thing off? I've finally gotten around to mapping out where to punch my hydraulics for the clutch and ended up ripping away the piece around the fusebox. I was just curious how in the heck to do it the right way next time.
Any info appreciated. Do people normally just cut the rubber plugs out and get new ones?
Thanks....
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 09-21-2006, 03:18 AM   #2
Bob B.
Re: How in the heck? Inner firewall padding removal.
Those fasteners are 'one-way'. They usually break when you try to remove them. The good news is most of the suppliers sell them, and they are not expensive.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 09-21-2006, 11:46 AM   #3
shifty
Questionable
shifty's Avatar
Perfect. Judging by the shape of the padding behind that cardboard, I should replace everything anyway....I think I'll wait till I'm ready to have the bodywork done, though.
Old 09-21-2006, 08:50 PM   #4
neonlarry
neonlarry's Avatar
I just took a tool made of flat stock with a 'V' notch and they poped out fine (reusable). That done you also have to remove two sets of rubber hoses and one set of electrical wires that go thru holes in the cardboard\padding.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
