Old 09-21-2006, 12:49 AM   #1
1966C10
New Member
Option Sheet
The option code sheet that is attached to the glove box door is all faded. Might be a stupid question.....But is there any place to get a reproduction of this sheet with the option codes. I would like to know what my truck came with from the Factory. Some codes are visable, but I would like to see them all. Thanks for any info............
1966C10 is offline   Reply With Quote
Old 09-21-2006, 06:10 AM   #2
Re: Option Sheet
The blank VIN-spec sheets are reproduced.You can type them up using IBM-type,like the factory did.You need to assess what options you have and get the RPO codes from a dealer order book or other source.I have the`71 book and can help if that`s your year.I believe the codes didn`t change,but have never looked into that.
Old 09-21-2006, 01:10 PM   #3
1966C10
New Member
Re: Option Sheet
Where would you find the dealer code book at? The year I have is 1967
Old 09-21-2006, 11:17 PM   #4
Re: Option Sheet
Search high and low,maybe you`ll find one.I realized after posting.Check the FAQs for restoration packets.LonghornMan knows more about it...pm?
