#1 | |||
Union Electrician
Need pics of brake lines
Does anybody have a pic of the brake lines(disc front) on their truck, Bare frame where I can see where they all should be? I have my 69 to use somewhat,but it has drums and the truck I'm building has discs so the lines in the front are different. Also does anybody have an extra rear end bracket that holds the rear block where the two hard lines and the flexible line connect? My rear end is missing this bracket and wanted to get it on and in place to finish up the rear brake lines. TIA ...Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
67 is sold
Re: Need pics of brake lines
Here are the pics of the brakelines I installed this summer
http://67-72chevytrucks.com/vboard/s...4&postcount=21 Here are the pics of my brakelines. I need to tweak the lines where they will meet up with the lines coming down from the master cylinder once I get the cab back on. I also need to install the clips, but you get the idea. And yes, I do have some touchup work to do on the finish of my frame ![]() Left side from the front view ![]() Right side from the front view ![]() Right side rear view ![]() Front crossmember ![]() Rear Hose to frame hard line ![]() rear end Tfitting ![]() ![]() ![]() |
#3 | |||
Union Electrician
THank Joe, I was wanting to see the x-member, that is where I am having trouble, going from the x-member up to the master, it doesn't seem like the lines are bent right?? Also my rear lines are different, lloke like they should hit a bracket to the left of the hog head(by about 5-6"), but the bracket is not there?
#4 | |
67 is sold
Regarding your rear lines, different years and different applications had brackets in different places. I would call the supplier of your lines and verify you have the right pieces. |
