Old 09-21-2006, 03:07 PM   #1
69CvyPickup4x
69CvyPickup4x's Avatar
wiring issue
i have a cs130 alternator on my 454, almost new.. i hooked up the wiring as i read in a few articles.. it was a 4 wire alternator and i "converted" it to a 2 wire alternator.. one wire goes to the battery and the other wire goes through a resistor and then into my fuse block which its on a switched ignition hot. The other 2 wires are capped off. After hooking it up i ran the truck on and off for a total of about 45 miles, great no problems. The other night i started it up and showed no volts on the gauge. I tested the alt. with a volt meter and had no power coming of the recharge terminal..Now im sorda baffeld because I re-wired the whole engine. Havent got to the cab wiring yet but i dont think that should make a difference with the charging system.. any help?? anybody experienced this??
69CvyPickup4x is offline   Reply With Quote
Old 09-21-2006, 08:44 PM   #2
neonlarry
neonlarry's Avatar
Re: wiring issue
And just how did you "converted" it to a 2 wire? You do know that the 'S' terminal is the voltage sensing wire that controls the alt output?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-21-2006, 08:45 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: wiring issue
Here, read this article and check it against your wiring and then check the resister in the brown wire,it might be blown. You need a 3 watt or bigger resister .IIRC.
http://www.chevelles.com/techref/tecref14.html
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-22-2006, 11:06 AM   #4
69CvyPickup4x
Re: wiring issue
well yes i do know the S wire is the sensing wire, i have the S wire jumped to the batt recharge terminal on the alt., the F wire is not connected, the L wire i have going to a resistor and then a switched hot, the P wire is not connected. I then have the batt recharge term. connected to positive side of batt.
Old 09-22-2006, 11:07 PM   #5
69CvyPickup4x
Re: wiring issue
so everyone else is as baffled as me?? i searched for the few hours i had today, for maybe a bare wire or something.. i bought a new battery.. i bought a new resistor.. still nothing, even though i kno the battery wouldnt change anything but i needed one anyway. i did notice when i put my blinker on and off, the volt gauge kinda jumps but only the littlest bit. i have nooo clue i wired it exactly how the tech forum says. i searched on pirate4x4, ck5, chevelle.com, camaro.net, gained all the info and its wired properly. The alt. is only 4,000 miles old, its a mean green.. im going to get it bench tested tomorrow.. maybe fluke deal it got burnt up or something huh?
