Old 09-21-2006, 05:14 PM   #1
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Front drive shaft CV joint
How important is the CV joint on a front drive shaft. Mine is completely worn to death. I'm going to replace the shaft, and it would, of course, be a great deal cheaper to have one made without the CV, or double cardon joint, if you want to be technical.
My truck is a 1967 with no lift, and no hope of ever getting one while I own it.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 09-21-2006, 05:56 PM   #2
Blazer1970
Blazer1970's Avatar
Re: Front drive shaft CV joint
You will likely get vibrations at high speeds if you eliminate the double cardan joint since the u-joint angles on the front shaft are not set up for a single joint at each end. If you only use 4WD at slow speeds, you can probably get away with it.
Blazer1970 is offline   Reply With Quote
Old 09-22-2006, 09:02 AM   #3
6869704X4
I rebuilt my cv joint back in 90 or so. If spicer still makes the parts its an option for you. If I remember right its not too hard of a job. I did it with hand tools.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 09-22-2006, 10:21 AM   #4
jacobs
jacobs's Avatar
I had a new front drive shaft made w/o the cv joint 14 years ago and have never regretted it. At highway speeds, I can't tell any difference when in 4 wheel drive - of course the only time it's in 4 wheel drive on the highway is when I forget to turn the hubs or when driving in snow. I highly recommend the conversion!
BTW if you're near Denver, I got my new transfer case yoke from Drive Train Industries.
jacobs is offline   Reply With Quote
Old 09-22-2006, 11:55 AM   #5
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
2 things
you have to have one to get over the crossmember
and with the married 205 it is so short that any flex will bind it up quickly.
if you have a divorced tcase or a 203/205 doubler setup it would be long enough to get away with it.
trkklr77 is offline   Reply With Quote
Old 09-22-2006, 01:58 PM   #6
jacobs
jacobs's Avatar
Originally Posted by trkklr77 View Post
2 things
My conversion was on a 1970 k20. It's tight above the crossmember but not that difficult. I've never had any problems with binding however I don't have any extra lift.
Old 09-22-2006, 04:49 PM   #7
boundstaffpress
I have a married Rockwell 221, not a 205. What difference will this make?
Justin
Old 09-22-2006, 05:05 PM   #8
6869704X4
Since you said you were not ever going to lift it then binding probably wont be an issue. jacobs had good luck with his, however, the factory felt that they needed one.
jacobs, how did you mount the the u-joint to the CV yoke on the transfer case? I'm guessing u-bolts?
Old 09-22-2006, 05:29 PM   #9
jacobs
jacobs's Avatar
I purchased a new yoke that used u-bolts. Drive Train Industries is a large distributor of products for primarily pickups through semi trucks. I explained what I wanted to them and they found a yoke that would work since the old yoke was different. If anyone needs the Spicer number for a 205, I believe I still have the old box the yoke came in.
Old 09-23-2006, 12:37 PM   #10
Yukon Jack
Yukon Jack's Avatar
My 1969 with the Rockwell T221 and a manual three speed came stock without a CV joint. When I lifted the truck I had to add on.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
