Aluminum slot wheels rule...
Quick question.......
I was just wondering, can you put Lakewood traction bars on a 3/4 ton pick-up? Sounds like a dumb idea, but it just popped in to my head so I thought I'd ask.
Re: Quick question.......
Coulda been quicker
its all about the +6 inches
the low buck slapper pars that I suspect you are refering to, (the ones for like 40 bucks or so that go on with U-bolts) they won't work, thy require that the axle be over the leaf, instead of under it.
Ok, thanks for the replies.
Make your own ladders,Jake.In the`80s I had these bars for 4wds called "Bushwackers".They were a 1" rod with an eye/bushing at the front and an l-bracket at the rear.The bracket bolted to the top of the u-bolts.You bolted a bracket to the front spring mount that the front of the rod bolted to.It sat over the spring.I had those on my green`71 Blazer that had a locker/4" blocks/37"Swampers and it eliminated spring wrap.They woulf be simple to make.
Yeah, they sound easy enough to make. But, I don't really need them on my truck. I don't think it would OR could spin enough to need them.
![]() Last edited by JAKES 68GMC; 09-23-2006 at 02:09 PM. |
It couldn`t burn rubber if you dumped gas on the tires and threw a match at it,eh?
She don't like to, not with the Posi and V6. Maybe when I put a SBC in she'll light 'em up.
It`s a hard thing to grow out of,I haven`t.
RIP Mr Ron
![]() Join Date: Dec 2005
I haven't either and I'm pushing 60.
Ron (Mr Round Tuit) ![]() Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
Why would one WANT to grow out of it? (32 goin on 17 here)
Actually,some grow "into" it.The older you get,the more smoke you can make.When I was younger,it thrilled me to actually lay a patch on the pavement.Then,it was how long,next making two at a time,now it`s sitting still in a cloud that sounds like a revving motor
#13 |
I took the old girl out in the tar today, and tried to spin her.
#14 |
Ah man,you`re doing the wrong thing.You need to hook that Jimmy to the Yokyto and pull it backwards with his wheels spinnin`forwards.Drag him into a ditch
#15 |
Fabricate till you "puke"
Got a cheap set of slapper bars on the longhorn(axle flip/drop). They work pretty good with a posi......but I am running a peg leg 3.40 rear. You dont stand on that 1 ,till its moving ......& its still lit for the first 4 gears
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#16 | |
![]() I wonder if those 73-up ladders bars in summit would fit my 68. I've seen them listed in there, too. I suppose if I really wanted some, I could try and make them......... |
