Old 09-21-2006, 10:02 PM   #1
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Exclamation adjusting a carb
I have a 2BBL that i think is out of adjustment, does anyone have any instructions on how to adjust one? It will run fine and if you gradually give it throttle it does just fine, but if you punch it, it will cut out and then pick back up, it's really bad if it is in gear and you are driving, it just has no power. Please help!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 09-21-2006, 11:11 PM   #2
jhow66
jhow66's Avatar
Re: adjusting a carb
Need more info-what brand of carb-new-rebuilt-just start this all at once-tells all you can about it.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 09-22-2006, 01:56 PM   #3
Firefighter
Rochester rebuilt by Tomco hot air choke
Yellville, Ar. USA
Old 09-22-2006, 03:44 PM   #4
71chevytruckguy
71chevytruckguy's Avatar
sounds like not enough timing to me. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 09-22-2006, 05:14 PM   #5
ThatOneBlue67
I survived Dead Man's Curve.
ThatOneBlue67's Avatar
Check your vacuum lines. If it's what I think it is (a back fire) maybe you should consider HEI ignition.
"The people should not be afraid of their government. The government should be afraid of it's people."
"The Hurricane"
1967 Chevrolet C10
350 Eight Cylinder, 700R4 BowtieOverdrive
Cherry Bomb... Disturbing the Peace Since 1968.
ThatOneBlue67 is offline   Reply With Quote
Old 09-22-2006, 06:18 PM   #6
Firefighter
vac lines new, distributor new, cap new, rotor new, HEI system already
Yellville, Ar. USA
Old 09-22-2006, 08:19 PM   #7
jhow66
jhow66's Avatar
1st thing to do is (WITH ENGINE OFF) look down into carb while you move the gas lever-there should be a stream of gas flowing out of pump holes as soon as you move the lever. If not the pump is bad or the pump lever is adjusted wrong or the rebuilders left a check ball out. If you are not getting a pump shot I would take it back and have them replace it.
