taillights and brake lights
I have a 1979 gmc heavy half I changed the valve covers a few months ago and ever since I changed them my brake lights,tail lights and dash lights go out every time i use them I change the fuses each time too then they just go out I havent got any idea why this happens because the valve covers have nothing to do with anything electrical if someone could clue me in as to why this is happening i'd appreciate it very much,I have only driven the truck 2x since I changed the valve covers and I want to start driving it since its finally cooled down here in las vegas.I really want to get this fixed asap so any help is good enough for me
Re: taillights and brake lights
hello,,so are you saying the fuse blow's everytime?? if so when does it blow??? when you pull light switch on?? push brake pedal?? need some more info...
Sb 400 club
maybe a ground strap from the mottor that got hit when installing the vlve covers. OR it could have nothing to do with them and this problem could just have started since you switched them. Melted wire?
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
I had a chevy van once, which blew out fuses to dash lights and tail lights, turns out that a bare wire in the rear under the van was intermittantly touching the frame.
it blows out when i press the brakes and it lasted for a little drive then i got home to go somewhere else and it went out again thank you for the help im goin to look at it weds so ill let you guys know what i can find thanks for all your help il take into consideration all the replys and check each one out.thanks guys
