Old 09-22-2006, 11:50 PM   #1
Nima
Blue 67
How to put the bearing and race back
Hello:
Hopefuly a good weekend is ahead of everybody. I am putting back my rear hubs back together but I can'rt get the outer race go all the way down ina way I can but the clip back. I don't have a press, I am using brake/race removal tool and tap them in place but now, I am hitting hard with no result. I am afraid to hit it harder. Any tip is greatly appreciated.
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 09-23-2006, 05:24 AM   #2
junkyardjohn
junkyardjohn's Avatar
Re: How to put the bearing and race back
Silly Question... But Are You Sure The New Races Are The Same Width As The Old Ones?? I Usally Put Them In With An Aluminum Race Driving Tool, But If I Don't Have On The Right Size I Use A Brass Drift Punch. I Can Always Tell When The Race Is Bottomed Out. You Won't Hurt It With Brass Or Aluminum, But Don't Be Tempted To Use Steel. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 09-23-2006, 05:56 AM   #3
cdowns
cdowns's Avatar
see if the autoparts store has the correct tool on thier loaner program// also put them in the freezer for a few hours b-4 trying to install them
Old 09-23-2006, 02:19 PM   #4
Nima
Blue 67
Well, I found that the race I bought from napa are slightly wider that the original. I can't find the original. I went to Napa, dealer, and some aftermarket/custom part stores. What is the down side of using the old race as long as they are in good shape? Any ideas?
Old 09-23-2006, 02:34 PM   #5
cdowns
cdowns's Avatar
i've used old bearing races quite a few times with no ill effects as long as they're smooth and not burned or rusted
Old 09-23-2006, 05:00 PM   #6
Nima
Blue 67
I think I found them!. I went to another napa and the guy was very helpful. The race look identical now, I am gona try it and see
