Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 09-23-2006, 11:58 AM   #1
67chevy2wd
67chevy2wd's Avatar
Which tool should I use?????
I am looking into getting a new grinder of some sort. I also want it to be my cut off tool. Should I go electric or air and which brand and size? Or should I even go with a grinder?
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 09-23-2006, 01:43 PM   #2
Sillyoldman
#16876
Sillyoldman's Avatar
Re: Which tool should I use?????
What are you cutting? I use a bandsaw for most of my cutting.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 09-23-2006, 02:03 PM   #3
67chevy2wd
67chevy2wd's Avatar
Sorry mostly cutting on body panels. I would love a plasma cutter but I dont' have the money right now.
'71 GMC 3/4 ton 4x4
Old 09-23-2006, 02:31 PM   #4
cdowns
cdowns's Avatar
for body panels and other light gauge sheetmetal i find it's tough to beat an inexpensive jigsaw
Old 09-23-2006, 03:05 PM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Make sure you have a big compressor if you plan to go with air. I have a big 115 volt compressor, and it is way too small. I found out my cutoff tool is good for a few seconds of cutting before it starts to turn too slowly to be of any real use.
I have been using a $17 Harbor Freight 4 1/2 inch grinder with a Dewalt cutoff wheel lately, and it works a lot better. It will do just fine until I can get a bigger compressor.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 09-23-2006, 03:05 PM   #6
krue
Designated A-hole!
krue's Avatar
If you're dead set on a grinder, get a 4.5" electric for grinding (about $30 @ Wally world) and a small air cut off tool (on sale @ HF all the time for $10).
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 09-23-2006, 04:16 PM   #7
68haywagon
I'm watching you!
I have the cheap HF air cutoff wheel....works great till ya run out of air after about a minute. I have a 4.5" electric grinder that I picked up at a tool sale for like $12, but haven't had the chance to try it out yet.
If you have some big sections to cut out I would not use air unless you have a big 2 stage compressor.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 09-23-2006, 04:55 PM   #8
67chevy2wd
67chevy2wd's Avatar
The air compressor I use is an 80gal hooked up to 220V, as far as stages I dont' know. I like the electric grinder but it just doesn't get into every place I want it to. I have a couple diegrinders but they just don't have the power to cut metal. Something like a jigsaw would be nice because I seem to burn up alot of cut off wheels.
'71 GMC 3/4 ton 4x4
Old 09-23-2006, 05:59 PM   #9
68C15
blood type; Retumbo
68C15's Avatar
you might consider what i refer to as a "fart saw". its like a sawzal but fits in your hand and runs off shop air. they work great for small areas and especially on sheet metal. best of all is there is no sparks and it stops instantly when you release the trigger (no cut fingers or limbs)
68C15 is offline   Reply With Quote
Old 09-23-2006, 07:48 PM   #10
>X<
registered IWATA user
>X<'s Avatar
at the body shop i worked at when i was younger we had a METABO tool that spun 4 or 6 inch cutoff wheels fast, fastest thing i have ever used next to a plasma.
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black
-'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end.
-01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny.
Take off that Von Dutch hat before i stab you with a 000 Mack.
>X< is offline   Reply With Quote
Old 09-23-2006, 07:52 PM   #11
67chevy2wd
67chevy2wd's Avatar
I think I know what you are talking about, we have one and it cuts anything and fast. It doesn't turn on like a grinder when you hit the switch it has to get wound up first. I am mostly wondering if there is any benefit to using air or electric.
'71 GMC 3/4 ton 4x4
Old 09-23-2006, 09:44 PM   #12
>X<
>X<'s Avatar
air tools are lighter and have less parts to break. i have a body saw (like a jigsaw but straight) a milwaulkee grinder that pretty much lives with a wire wheel on it, a IR air angle grinder with a roloc head, a high speed 3" cutoff wheel tool, a sawzall, and a friend with a plasma. for sheetmetal the cutoff wheel gets used most and for grinding the little IR with 36 grit roloc discs gets used 90% of the time. combined they were still cheaper than a good electric grinder or metabo.
Old 09-23-2006, 10:19 PM   #13
67chevy2wd
67chevy2wd's Avatar
I have never heard of a roloc disk. Is it a brand or a type of disk?
'71 GMC 3/4 ton 4x4
Old 09-23-2006, 11:33 PM   #14
jcueckert13
jcueckert13's Avatar
its a round abrasive disk used on a dye grinder, at work we use them to remove gasket material.
1990 subaru legcy (daily driver)
1987 Toyota 4runner (weekend toy)
1968 C30 flatbed dually
1970 C10 longbed stepside (in pieces)
1976 Dodge Dart
1963 Dodge Dart
jcueckert13 is offline   Reply With Quote
Old 09-24-2006, 12:36 AM   #15
>X<
>X<'s Avatar
3m makes them. they are the ONLY thing to use for grinding welds on this (automotive) metal. they come in 2" and 3" discs ranging from 24 grit to 180 grit, also available in scotch brite pads (what jkqkert is referring to) and bristle discs. way less heat and faster than big grinders.
Old 09-24-2006, 12:54 AM   #16
67chevy2wd
67chevy2wd's Avatar
Ok I know what the scotchbrit ones are and the bristle ones. Thanks i will have to check into it.
'71 GMC 3/4 ton 4x4
Old 09-25-2006, 12:48 AM   #17
Sillyoldman
#16876
Heck. Get Both an electric and a air tool. I have a electric and use it more than I thought I would. It even cuts off steel fence posts and you only have to drag a cord around. I do love the A-tools too. They sometimes seem to be job specific, but when you get in a bind that forgotten air tool will be handy.
Old 09-25-2006, 06:12 AM   #18
mbgmike
If you are working with sheetmetal believe me, You will end up with just about very tool. AIr or Electric,even manual.
mbgmike is offline   Reply With Quote
Old 09-25-2006, 10:57 AM   #19
shifty
Questionable
shifty's Avatar
Cutoff wheels can be sloppy, make a mess and slower than a .jigsaw, which cuts through body panels like butter.
I went to Lowes and got a Dewalt 4½" angle grinder for grinding and a pack of metal cutting blades for my jigsaw. I've cut out all kinds of stuff - I cut out my tranny hump just the other day, as a matter of fact.
A grinder (electric) can double as a sander as well, you just need the attachment, which I think is like $7 at your local hardware chain store.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
