Old 09-23-2006, 08:21 PM   #1
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
Front End Clunk
The PO installed Early Classic's 2/4 drop kit with the panhard bar and shocks. (springs only) Whenever I "flex" the suspension driving or lifting I can hear a clunk that sounds like a spring shifting. Maybe he installed them wrong? Or left out a pad or something? I've never installed a kit so I'm not really sure what's involved. I did install new ball joints & tie rods. The control arm bushings were good also. Any ideas?
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 09-23-2006, 08:57 PM   #2
clay68c10
clay68c10's Avatar
Re: Front End Clunk
Tighten down everything, including the body mounts and front crossmember bolts. After 30+ years anything could be loose.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-23-2006, 08:58 PM   #3
rage'nrat638
rage'nrat638's Avatar
Re: Front End Clunk
about the only thing i can think of is have someone jack it up slowly and listen for the clunk to find where it's coming from..?
rage'nrat638 is offline   Reply With Quote
Old 09-23-2006, 09:00 PM   #4
uncle
Re: Front End Clunk
Try putting more grease in the ball joints, sometimes they will clunk if they don' have enough grease.
uncle is offline   Reply With Quote
Old 09-24-2006, 01:13 AM   #5
jooooooe
Re: Front End Clunk
the lower control arm has a indentation in it for the end coil to seat in, if the coil spring isn't turned right, it will cause a binding nose....a clunk
jooooooe is offline   Reply With Quote
