Old 08-12-2002, 10:18 PM   #1
bigjimzlll
bigjimzlll's Avatar
spark plug wire question
Ok...im getting POed... ive been having a dickens of a time getting the new motor timed...I pulled a few plug wires off while running.. one didnt seam to make much of a difference, so i pulled the plug..it look good..ohmed the wire and got nada..then i screwed with it a bit and got 12kohms..whats the correct reading supposed to be? and would bad wires cause my timing delima?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 08-13-2002, 01:39 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
sounds like a wire or 2 are burned.....i'd replace the whole set as the next step.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
