Old 09-24-2006, 12:58 AM   #1
Nima
Blue 67
Frustrated!!
Well, after almost two months I had a day to work on my truck. If you have seen my previos post you know my problem with the rear bearing and race. Anyways, I found out in a very hard way that 3 out of 4 parts that Napa guy gave me were wrong . being a first timer I took his advise and took the race that was slightly wider than my original. I found that mistake after I packed the bearing and tapped the race in. It didn't clear the groove that the snap ring was suppose to go. in to it. After posting here and taking the hubs to a shop I ended up disassemble the hub and take the race back to the same napa. The guy looked at them and said "well I don't have anything else!" therefore I returned them. Later on after going to God knows how many store and dealer, I started to debate to use my old races then I decided to go to another napa just for the heck of it. The guy looked at my bearings and his computer then went back and after less than a minute came back with two races identical to my original!. I couldn't believe it!. I came back home packed the bearing and then the races wnet in just with a little tap, snap ring snap in place with almost with no effort . Now, I instal the outer race and bearing and seal. I put the disc (concverting to disc) and hammered the studs in, lifted the hole thing up to put it over the axel. It DID not go in! . The outer bearing inner ring is slightly smaller!!! I took the bearing from the other side and compare to the old one , they look the same but it seemed that the inner ring is slightly smaller. Took that bearing with the original to the second napa which found the races, and the guy just by looking at it said they are different!!!. He looked up his books and found a number but he didn't have in stock until Monday. Oh boy, Now I have to disassemble everything, do nothing until monday and drink beer to forget my wasted day
I just needed to went, Thanks for listening
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 09-24-2006, 12:05 PM   #2
Bob Moore
Re: Frustrated!!
Sometimes life is frustrating. On the plus side, you found a good parts man and can at least get the parts. After several months a few days more will seem like nothing.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 09-24-2006, 10:13 PM   #3
Green Machine
Green Machine's Avatar
Re: Frustrated!!
It goes that way some times, I just spent the last 2 1/2 days redoing the engine and front wiring harnesss on our 70. Takes a lot longer than you think some times. Went to put in the headlight buckets and got them switched left to right, could not figure out why the lights would not go in. Got that fixed and then put the rings on, forgot about the notch for the springs, took that all apart again, lost the screws three times and had to hunt all over. Took about 2 hours to put in headlights !!! WTF??. Went to put in the drive shaft, got it all in place ready to tighten the u bolts and figured out that a needle had dropped. Take it back out again and fix the needle, and of course tranny fluild had to spill on the garage floor !!! Yesterday I tried to install a new taillight bezel and bent the sh1t out of it, thin repro crap !, now I have to order 2 more, because the other side was damaged in the package, another $25 bucks down the tube. I have many more examples but I am going to quit here before I get depressed !!! Sometmes it just goes slow and it is only a mistake if you leave it unfixed or half-azzed.
Good thing tommorow is Monday - I'd quit my job, but I need the rest !!!!
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 09-24-2006, 10:39 PM   #4
krue
Designated A-hole!
krue's Avatar
Re: Frustrated!!
I feel y'alls pain. I agree about finding a good parts man, that's like finding a diamond in a turd anymore.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 09-25-2006, 12:13 AM   #5
Nima
Blue 67
Re: Frustrated!!
yep, some times life sucks but the main thing is getting up and trying again
Old 09-25-2006, 01:01 AM   #6
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Re: Frustrated!!
What the heck were you doing looking in a turd? it must've been the turd of Tom cruise's kid ewwwww
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
