09-24-2006, 01:14 AM | #1 |
Questionable
press brake + drill press purchase advice
Hi all,
I am looking for an inexpensive drill press and press brake for my shop. I do not need anything fancy and don't need to bend or drill anything larger than, say, 10 gauge mild steel. I saw they had a 12 ton press brake at Harbor Freight for around $100. I also have seen several drill presses, but I'll admit, it's daunting to find the right one, or to even know what the heck I need in a drill press...I found a 16.5" floor standing one, old Craftsman for $100 on craigslist....not sure if I should pick it up? I'm sure some of you guys can give inexpensive recommendations, so I'm curious to see if anyone has good advice. Mind you, I am not going to be running a freaking shop and these tools will not get more than a dozen uses per year, so I am not looking for anything fancy (hence why I would buy something from HF) Thanks!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
09-24-2006, 01:40 AM | #2 |
Re: press brake + drill press purchase advice
I picked up a $150 Home Depot drill press three years ago (it's a Ryobi)... I had to have one that day for something and figured that when it broke I would replace it with a "nice" one... it's still going strong and gets used quite regularly.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
09-24-2006, 05:50 AM | #3 |
i've got an older craftsman drill press it was about top of the line back then// i like big heavy bases, big heavy girder , powerfull motor, big work table that you can easily clamp things to that tilts both left and right, the belt should be easy to change ,tighten and adjust speeds with, i also needed a unit that you can easily ghange out the chuck and would accept a 1 inch chuck// the thing to watch on used machines is worn bearings and stripped gears in the spindle and feed area HEAVY is good
09-24-2006, 06:39 AM | #4 |
Search the local paper:classifieds and sales/auctions.The old stuff is all industrial rated.I got a 5' brake for $75 at a sale.
09-24-2006, 10:45 AM | #5 |
Cantankerous Geezer
For a drill press, get a floor mount. I bought the HF 43389 a few years ago. Only problem has been the switch, poor design that I had to replace. Unless you have to have one right away, wait for HF to have a sale. The older used presses are good, but around here people want too much for them.
I don't know about the HF brake. You can do some comparing at Northern Tool
Fred There is no such thing as too much cam...just not enough engine. |
09-24-2006, 10:59 AM | #6 |
looked at this same model yesterday at our local HF ... not industrial grade, but not bad for home use.
http://www.harborfreight.com/cpi/cta...emnumber=91012 |
