Old 08-12-2002, 10:50 PM   #1
moose
a/c question
has any one canverted a non air cab to a air cab with original equipment either useing the vent or making new ones i bought
a set up at the u pullit tonight most every thing there execpt compreser but I already had one how hard is thid to do. I like put the vents under the dash instead of drilling and cuting for the original vents IF anybody has done this please post picture thanks
69 C/10 swb coming along slow but sure 4 yr and counting Omaha Nebr
7I JIMMY 350 4speed daily driver/next prodject
99Yukon wifes
moose is offline   Reply With Quote
Old 08-13-2002, 09:36 AM   #2
ckhd
ckhd's Avatar
The firewall on a non-A/C cab is different than an A/C cab. I don't know how hard it is to make it work anyway...
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 08-13-2002, 01:44 PM   #3
Hutch
Hutch's Avatar
A/c work is extremely high nowdays due to the restrictions placed on the industry by the federal goverment due to enviromental concerns, My truck came with the factory air option and all the parts were with the truck. I installed a new compressor dryer and exp valve flushed sysyem converted to r134a and replaced various seals and hoses. and got out for about $800
You could get it done for about half of that if you have a friend in the a/c business.
There are companies that make a system for these trucks using newer components either for a factory a/c truck or truck without original a/c.
I would think that you would be alot happier with the end results using one of these kits. the older systems have to be optimized to get the performance that the newer systems deliver.
Old Air
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 08-13-2002, 05:19 PM   #4
Low69CST
The difference between A/C cabs and non A/C cabs is the number of holes stamped into them. Alot of these holes are marked from the factory. I'm in the process of converting my cab. I cut out the vents in the dash, cut the firewall too. Just get an old A/C cab for a pattern and start cutting. We found a rotted out A/C and made cardboard patterns. Let me know if you want to see some pics.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
