09-24-2006, 11:59 AM | #1 |
Traceing a short ????
My 69 chev. cst p/u keeps blowing the fuse for my tailights and interior lights ..It only does it after about 20- 30 minutes after driveing ..It seems like it has to get warmed up ..I'm pretty sure it is in my dash lights panel but i could be wrong. My ? is how can i trace this back w/ o going nuts . I plan on installing a new painless wireing harness soon but don't have the cash flow and would like to drive it to get my doors and hood painted. and to get other work done .. any help at all is greatly appreciated and thanks in advance for any help .. thanks, Dandeluxe
1969 cst swb 350/400 th . DANNY C . ["]FRIENDS DONT LET FRIENDS DRIVE F@RD$!! 1969 cst swb corvette hugger orange with 400 hp sbc I started out with nothing and i held on to it |
09-24-2006, 01:30 PM | #2 |
Re: Traceing a short ????
it's easy to inspect the taillight harness you get on your back crawl under the truck with a light and look at the harness inch by inch and use your fingers to feel if theres cracks in the insulation especially where the harness is held by clips to the frame rail// if you dont find anything there repeat procedure under the dashboard
09-24-2006, 04:49 PM | #3 |
Thanks!!! I Will Try That C Downs
09-24-2006, 05:35 PM | #4 |
If you don't find it you can always splice an inline fuse in the wiring leaving the dash. Size the fuse one amp less than the fuse panel fuse and see which one blows. If the fuse panel fuse blows its probably in the dash. If the fuse in the wiring leaving the dash blows you have a problem farther back towards the tail lights. You can move it all the way to the back in between the lights to see which one is blowing the fuse. If you don't have a short all the time thats one way of finding it. Tom
09-24-2006, 06:01 PM | #5 |
Start unpluging things too and see if the fuse still blows. For example unplug the tailights back at the rear crossmember and see if the fuse still blows.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
09-24-2006, 06:11 PM | #6 |
Thanks guys, I am considering going with this idea on the problem..
http://www.itsasnapwireandcable.com/new_page_6.htm
09-24-2006, 06:21 PM | #7 |
DON'T TREAD ON ME
I agree with cdowns, I'll bet your problem is in the taillight harness. I had the same problem which turned out to be where the harness split off and went to my trailer light connector. One of the wires was laying on a brace in my bumper and shorting out where all the insulation rubbed off. Since then I've removed the entire taillight harness and replaced everything from the firewall back to the taillights because all the insulation was dryrotted and peeling off.
Old Yeller |
09-25-2006, 12:01 AM | #8 |
Thanks !!! i'll try these suggestions
09-25-2006, 06:15 AM | #9 |
I had my taillights blow fuses and put a new ground between the frame and the bed near the back and no more blown fuses. You get too much resistance in the circuit and pull too much current and blow the fuses. Run a 12 gauge wire between the rear frame driverside and the rear cross member of the bed holes are already there on mine, scratch the surface good before you put the wire on tighten them down and then paint them.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
09-25-2006, 07:06 PM | #10 | |
Tool Addiction=Money Shortage
Amps = volts divided by resistance So more Resistance= less amps |
09-26-2006, 06:12 AM | #11 |
ND_guy I agree but when you have a bad ground and the current goes from 13amp? (bad ground) to 20 amps? (good ground) fuses blow(rapid current rise). Just my experience bad ground on rear lights blows fuses. The other thing that will cause fuses to blow is dirty or corroded fuse block. Increased resistance causes heat at the fuse and melts the fuse. check and see if the fuse block is hot. again just my own past experience.
