I survived Dead Man's Curve.
I've read several posts talking about the 305 V6 engines in these old trucks. I thought 305 was a V8! In fact I know it is! Me and my pal broke into "triple digit speed" in his '92 Camaro RS last night. I'd be suprised to think that a V6 could drive as hard as
So is he confused about the number of cylinders in his car or are there 305 six cylinders AND eight cylinders? Speakin' of which, he has an "extra" 305 laying around and has no use for it. Do you think this would be an improvement to a 250 inline six?
"The people should not be afraid of their government. The government should be afraid of it's people." "The Hurricane" 1967 Chevrolet C10 350 Eight Cylinder, 700R4 BowtieOverdrive Cherry Bomb... Disturbing the Peace Since 1968. ![]() |
member #16
![]() Join Date: Dec 1999
Re: Motor Confusion...
The 305 V/6 engines are GMC only engines.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Designated A-hole!
Both, 305 sbc had eight small cylinders, while a GMC 305 v-6 has 6 large cylinders. If you want a huge v-6 they also made a 351.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
I just swapped a perfectly good 250/6 for a 305 just because I had one sitting around, but since I hate 305's so much I know I'll live to regret it, I already do as a matter of fact.. if your gonna' move up to a V8, move up to one worth your time. I say that because the 305 is limited in it's performance output, although, if you don't plan to do any HotRodding and you don't wish to push beyond 325 HP, a 305 is fine.
#5 | |
Where's my beer?
I think I know you!! you work at my local auto parts joint, do you drive a honda by any chance? ![]() ![]() Now seriusly, do some reading at this website here and get your "facts" straight. This is a 305 V-6 engine... ![]() Nothing like the wimpy 305 in your pals camaro ![]()
Paul How do you make the invisible, visible?.........You take it away. Last edited by chevy_fatman; 09-24-2006 at 07:25 PM. |
#6 | |
Location: vacaville ca, because it as far from indy as i can be
the only v6 after the early 60 were the 2.8, 4.3, and the 4gen camaro 3.8. i wouldnt be surprised if he had a 4.3 that would hit 100. the 2.8 and 4.3 were not tpi motors and its very obvious if that what youve got. |
Nah, you got it wrong. He already knew his 305 was a V8. I just find it suprising that a 305 came in both 6 and 8 cylinders and that someone had screwed up somewhere.
Haha! Fatman! That was so funny! .....You're lucky "State of Denial" isn't on a map. As far as a 305 smallblock being inferior to the 305 V6, that must explain why I see so many 305 V6's around.
the 305 v6 is a old and only a old motor, there are no new 305v6's, there is no comparison between them. your talking about a large bore/stroke small carbed old tech motor againts a roller small stroke efi better flowing castings new tech stuff, both have there place but neither one is worth more than scrap to 99% of the population.
if you have a 305 v6 you pull it out for a v8, if you have a 305 v8 you pull it out for a 350. |
I know the speech man. The old motor was for hauling and this Camaro V8 is more for speed yada yada yada. BUT, as you also mentioned, they each have their own special place.
That one dude was saying how much better the 305 six cylinder model wwas SO MUCH better than the eight cylinder one. Evidently not true as I think we would still be seeing a lot more today.
Try explaining to the pimple faced little brat at Checkers that you have a 1972 CHEVROLET 307. One day I finally turned and walked out of the store when the kid was trying to tell me it was a Pontiac or Olds 307.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
I'm watching you!
Ok heres a good comparison for you.
A 305 V-6, depending on which model, made any where from 260 to 280 ft lbs of torque at 1600rpm or under. A 92 Camaro RS 5.0l (305) makes 255 ft lbs at 2400rpm. Torque is what a truck needs to move when it pulls or hauls anything. This old technology made that power down low enough to allow the truck to pull. A carb swap alone probably allows that motor to make 275-300 ft lbs. I'm don't own either one of these motors and quite frankly I don't want to. The 305 V6 can not rev that high because of it's design and the 305 V8 does not have enough displacement to make the power I eventually want. No where here do I see a post where he someone say that the v-6s are SO MUCH better then the v8s. So I don't know who sent you a PM or deleted their comment, but each engine has their own application. One motor is not decisively better then the other. The v6 will out pull and most likely live longer if taken care of, but the v8 will smoke the v6 when its not pulling. Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold ![]() |
![]() Join Date: Nov 2004
I owned an '86 camaro Z28 with a 305. Piece of **** motor. Would never own or install another one in any vehicle I own. The car ran/drove like a top, but was gutless, I was almost embarassed it had Z28 badges on the car (my '86 toyota truck with a 4 cylinder 5 speed would break triple digits too.). I would keep your six popper over the 305, you'll be happier. If you're going to drop some coin on a V-8 swap go with a 350, a 305 isn't worth it.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 09-25-2006 at 11:16 AM. |
#13 |
Try finding parts for a 305 V6, thats the main problem with those engines. Otherwise, they are good for pulling stumps. I used to own a '78 Monte and a '78 Impala, both had 305 V8's. I found they are good motors to put in a car. Good for regular driving, reasonable gas mileage etc.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
#14 |
67-72 parts finder
why is everyone infatuated with 350's i've seen 283's and 327's that would run circles around "built" 350's
![]() ![]() 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
#15 |
Aluminum slot wheels rule...
The only thing a GMC V6 is good for is a farm truck that'll never have to go past 50mph. Granted, I love these motor's to death, they are wicked cool and have oodles of torque, but a V8 is much more practical on the street it's not even funny. Think, when I get a 350 in my truck, I'll be able to go past 55mph without wondering if the motor will blow up.
#16 |
In 1991 I bought a new S-10 with the 4.3 and a 5 speed, one night my friend, who was in a z/28, was sitting in front of me at a 4 way intersection and nail it when he took-off. I gave chase, caught him and squalled 3rd gear as I passed his front fender. I even hesitated 2-3 seconds before I left the intersection.
#17 | |
Fatman stated that the 305 V8 was a "wimpy" motor compared to the 305 V6 (he's obviously full of crap there). Why in the Hell would I want a 305 V6? I ain't a farmer. SOOOO, it does better at high speeds then the 6er. I told ya man, I know all that low end torque junk.
People probably prefer 350's cus there just about the most 'universal' motor out there. AND they're still in production. 283's were out by 1968. Quote:
"The people should not be afraid of their government. The government should be afraid of it's people." "The Hurricane" 1967 Chevrolet C10 350 Eight Cylinder, 700R4 BowtieOverdrive Cherry Bomb... Disturbing the Peace Since 1968. ![]() Last edited by ThatOneBlue67; 09-25-2006 at 11:57 PM. Reason: Quotation confusion? |
#18 |
its all about the +6 inches
The 305 was practicly an indestructable engine. It was perfect for the day, and was one of the hardest working engines of it's time period.
They can go over 55... you need better gears. A 350 in that truck will rev at the EXACT SAME RPM. the 3.8 was not a camaro engine, it is a buick engine out of the early 70's, maybe even the late 60's IIRC. The anemic 305 V-8 is not a bad engine, it just doesn't belong in a hot rod (camaro) nor a real work truck. if you just drive your car/truck to get from A to B, then a 305 will be fine. If you expect horse power or torque, look elsewhere. The 283 and 327 were great motors, however, to say a built 283/327 running circles around a 350... well, apples to oranges... make that a built 350 and your argument doesn't hold any water. Those 2 smaller engines were phased out becouse they needed higher RPMs to make the power that was needed. With the EPA requirements, and the CAFE requirements, they could not be made to work properly. BOTH 305's are great motors. As for swapping an inline for a 305, you'll probably be disapointed, but hey, try it, you can always fix your mistake with a 350, or going back to the inline. |
#19 |
Java Mechanic
The 302, 307, 327, 350 and 400 are nearly identical. All else being equal -- there is no substitute for cubic inches. 350s and 400s make the best hot rod motors and can very reasonably be punched out to about 430 cubic inches.
I really wouldn't fuss with a 283 unless you have a resto that started with one. They can be tweaked up but they have an annoying tendency to chuck robs if they are pushed too hard. The "305" is really just an updated 283. The more recent 5 liter motor, though of the same displacement as the "305" is a whole different animal. The large bore v6 motors are really interesting but if you really want torque then listen to Andy (I mean about the inline, though a Caddy BB is no slouch... lol) If you want torque *and* high end power -- nothing beats a rat. In the end -- nothing is "better" until you define your application. A 302 with twin carbs makes a fine stock car motor but it won't haul a trailer up hill.
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
#20 |
If you want a Camaro motor in your truck,put one in.Don`t knock one of the best truck motors ever built.At least not on a vintage GM truck site.These "are" trucks and believe it or not,some people actually use these things to pull and haul heavy things that a Camaro won`t do.In that way,the 305 is "wimpy".That first V6 went into medium duty trucks as well.Speed was not the focus,getting all that stuff up the road was.In vintage speed circles,the GMC V6s got warmed over and supercharged and were capable of awesome quick ETs.These trucks outweigh a Camaro by a good bit.Your results with,even,an H.O.305 will not be the same.
You are not comparing apples to apples,the arguement is pointless.But,you did say,"I`d be surprised a V6 could drive as hard as..."I assume you would say 305/V8.Let`s assume you meant any V8 to give you a stronger arguement.Ever heard about the Buick Grand Nationals or GSXs?They eat big blocks and spit them out.Capeesh? The GMC V6s were phased-out because of emmissions and fuel economy concerns.Also,buyer mentality..."why not get a V8 if the V6 gets the same mileage?"The world`s moving faster than back then,too.Not such a good thing IMHO. I wouldn`t want a 305(V8),but wouldn`t stop anyone else.If I looked at buying a truck that had a 305 V8,I`d look at it as a truck w/o a motor.I`d prolly not be able to sell-off the motor for any considerable sum."Why run a 305 when 350s are so abundant?"If I was focused on high-performance,Why not go "BIGGER"???!!!! The 305V6 is a gas motor that pulls like a diesel.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 09-26-2006 at 07:50 AM. |
#21 |
I'm watching you!
Both above me RIGHT and AMEN!!!
#22 | |
Where's my beer?
Now that it has been explained, do you have anymore doubts?
Paul How do you make the invisible, visible?.........You take it away. |
#23 | |
![]() Andy I know a 350 will turn up the same RPM in my truck, but the 305 V6 is really screaming at 2700rpm, almost redlined, where a 350 would be in its cruising rpm, IMO. I could be wrong though. That may be screaming in a 350, too. |
#24 |
Happy to be here
![]() Join Date: Mar 2000
Keep it civil please...
#25 |
my bad... seen way too many ppl make the mistake, thinking that since a small block will rev better than a 6, and get all bent out of shape to discover the same screaming sensation with the replacement engine. 2700 is starting to get up there a little bit. (I go screaming down the freeway well into the 3ooo to 35oo RPM range every morning...even higher if I'm in a hurry)
