New Summit Dizzy.........now tach doesnt work
Hey everyone I bougt a new dizzy from Summit. The only diff in this one and the stock one is there was a third metal tab in the 3 prong plug. Well I didnt think that was wierd because the new cap and plug had 3 connctions the old one only 2. It runs so much better now. I stabbed it one time and timed it to 10 degrees with the vaccum advance pluged. Absolutly no spark knock. It acts like the tach is going bacwards. It worked perfect with the old dizzy.
Any suggestions guys. Thanks in advance. Tony this is in my 76 K15 350 the part number is SUM-850001R
Tony ![]() "Life is a Team Sport" To the memory of the Hendrick Motorsports Plane Crash Victims Last edited by Paso76GMCstepper; 09-25-2006 at 12:14 AM. Reason: spelling errors |
Re: New Summit Dizzy.........now tach doesnt work
Are you saying the new cap or old cap had three connections? Have you pulled the dust covers on both caps and compared the coil connections? It would be possible to get the coil leads in the wrong position on the cap.
Well the new one has 3 connections. The old plug had the place for a third but its blank. The new one has 3 prongs insted of two. I didnt check under the dust cap. It that was the problem would it still run so well?
Let me know Im gonna go on a dump run with her and will look into it more when I get home in a fw hours. Thaks for the help/ Im gonna call Sumit this morning also
Tony ![]() "Life is a Team Sport" To the memory of the Hendrick Motorsports Plane Crash Victims |
I don't know what affect crossing the leads would have on performance. I remembered that the coil wires were simple to cross up. I had the HEI apart too many times before I just replaced it. You might want to also make sure the connectors are properly seated and aren't coming loose. I have had issues in the past because of that.
