Old 09-25-2006, 07:16 PM   #1
futura72
does a 3.5 x 5 drop need a c-notch and drop center crossmember?
I have a 72 1/2ton SWB, I'm planning to drop 3.5" x 5". I find mixed results in the boards about notching the frame and adding a drop crossmember. Anybody with the same ride having problems?
futura72 is offline   Reply With Quote
Old 09-25-2006, 08:24 PM   #2
centsless
sufficiently talented fool
centsless's Avatar
Re: does a 3.5 x 5 drop need a c-notch and drop center crossmember?
I just put 3" front and 5" rear springs in my 72. No other mods were done and the only issues I am having is the exhaust is hitting the panhard bar mount on the right side, I am going to put an adjustable panhard bar on so hopefully a shorter bar will help that. The axle is now off center by about 1/2 inch so other than the exhaust clearance, a shorter bar isn't needed, but it will correct that also. On the front I just need to shorten or remove the front lower bump stops. It rides OK, but if I fix these two things it would be better.
Bob
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 09-25-2006, 10:07 PM   #3
CG
BlahBlahBlah
Ive read on this board you can do a 4/6 drop, but if you use your truck to haul stuff around you will hit without a notch. Not true with burbs or panels because they are heavier in the rear.
Old 09-25-2006, 10:28 PM   #4
JustLiveIt
JustLiveIt's Avatar
I have a 4/6 on mine that is all spring (no drop spindles). I don't have a C-notch and it works ok. I just don't have much travel in the front or back. Bottoms out very easily. I also have a 2 piece driveline. From the looks of my truck you would need a drop center cross member if you wanted to run a 1 piece. Also my driveline angles are not what they should be because of the 6 inch drop in the rear.
1968 Chev SWB Fleet with GMC Clip and lots of 71-72 parts!
JustLiveIt is offline   Reply With Quote
Old 09-26-2006, 01:25 AM   #5
futura72
Thanks for the input. I'm really trying to save over $300 in parts i may not need and the labor of putting them in. I think I'll use that money towards front and rear swaybars and go without the drop center and c.
Old 09-26-2006, 11:10 AM   #6
case_bt
case_bt's Avatar
I have a 3/5 drop on mine no problems with it no c-notch either
Last edited by case_bt; 09-26-2006 at 11:10 AM. Reason: typing with broke hand lol
case_bt is offline   Reply With Quote
Old 09-26-2006, 11:11 AM   #7
case_bt
case_bt's Avatar
here it is
Old 09-26-2006, 06:13 PM   #8
futura72
that is the exact stance i am going for. looks great.
Old 09-26-2006, 09:46 PM   #9
centsless
centsless's Avatar
Nice truck case_bt !! Here is mine with 3/5 drop and 17" Impala SS wheels.
Attachment 217217
2003 Suburban
1981 Corvette
Old 09-27-2006, 12:31 AM   #10
pissonNOS
senior member
pissonNOS's Avatar
whatd u use for coils all around all i did was cut my front coils and put 2 inch blocks out back it rides pretty decent but id sacriice ride for look seeing as i dont drive it much
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 09-27-2006, 01:32 AM   #11
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Attachment 217217
Super looking truck, I love the stance, navy blue paint and how the wheels cap it off. How did you do the drop and what sizes are the tires?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 09-27-2006, 09:23 AM   #12
JustLiveIt
JustLiveIt's Avatar
PO put the coils on it so unfortunately I am not sure where they came from. I would like to replace the front setup with 1" drop coils and drop spindles from Early Classic.
Old 09-27-2006, 10:28 AM   #13
c10crazy
Like a Rock!
c10crazy's Avatar
[QUOTE=centsless;1814037]Nice truck case_bt !! Here is mine with 3/5 drop and 17" Impala SS wheels.
Beautiful truck but that looks more like a 2/4 drop with all that space above the tires.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 09-27-2006, 10:33 AM   #14
Jimbotronics
YA YA
Jimbotronics's Avatar
I have a question. I just installed the 3" front drop springs, if i lift the front end off the ground by the front cross member the springs are way loose and fall outta place. Is this normal? Thanks, Jim.
btw - do you happen to have a side profile photo of you truck? Looks sharp!
Jimbo
'72 SWB - 350 (frame-off resto in progress - donations accepted)
'04 Chevy Avalanche
'03 Cadillac CTS (wife's ride)
Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707
Jimbotronics is offline   Reply With Quote
Old 09-27-2006, 01:48 PM   #15
case_bt
case_bt's Avatar
the springs getting loose doesn't seem right make sure they are seated properly
Old 09-27-2006, 02:22 PM   #16
CJJ67
I have a 3/4 drop on my 67 sb stepside (but would love to get a little lower) and my springs are loose or fall out of place when i jack up my front end also. The ride is fairly smooth but sometimes I forget to put the springs back in their indents. So, this is not normal?
CJJ67 is offline   Reply With Quote
Old 09-27-2006, 04:12 PM   #17
see ten
WTB this ad
see ten's Avatar
Yep, 3" drop springs will fall over when you jack up your truck by the crossmember.
see ten is offline   Reply With Quote
Old 09-27-2006, 05:44 PM   #18
boraxman
Keepin an eye out
boraxman's Avatar
I have 3-5 spring drop and everything is fine, you can do it yourself easy. Get a pic up later.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 09-27-2006, 05:44 PM   #19
centsless
centsless's Avatar
Drop was done with springs only. 3" front, 5" rear. Front tires are 255/50zr17, rear tires are 255/60vr17. The color is 2006 chevrolet impala laser blue.Mine also loses the front springs when you jack it up by the crossmember. I thought it was because it is missing the rubber bump stops on the upper control arm.
2003 Suburban
1981 Corvette
Old 09-27-2006, 05:47 PM   #20
case_bt
case_bt's Avatar
took me 1.5 hours
Old 09-27-2006, 06:25 PM   #21
redneckgirl
redneckgirl's Avatar
[QUOTE=c10crazy;1814394]
It is a 3/5 drop. Since that pic was taken, we changed the rear tires to the 255/60vr17 and it helped fill the wheel wells. The 255/50zr17's are still a little too low of profile even for a 3" drop on the front. We measured height before & after to be sure we had the correct springs, so I can assure you it actually is a 3/5 drop.
You should have seen all the clearance before we swapped springs!!!
The place where you made your stand never mattered. Only that you were there... and still on your feet.
Stephen King
redneckgirl is offline   Reply With Quote
