Old 09-26-2006, 03:34 PM   #1
mr.wilson
Which transmission should I use?
I am installing a carbureted 6.0 with ls6 heads/z06 cam. I have a turbo 350 in it now, but I would like to go overdrive. Any input would be great.
Wilson
1972 Cheyenne LWB, 350ci TH-350.
Restoration in progress.
mr.wilson is offline   Reply With Quote
Old 09-26-2006, 03:54 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Which transmission should I use?
the turbo 350 IS an auto.
Old 09-26-2006, 04:29 PM   #3
jamon8
jamon8's Avatar
t-56 all day long baby
dont have one but WANT ONE
If you are looking for an auto
4L80e every day of the week
jamon8 is offline   Reply With Quote
Old 09-26-2006, 05:29 PM   #4
Longhorn Man
4L80E would be VERY expensive to install and hook up.
Old 09-26-2006, 06:04 PM   #5
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
th400
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 09-26-2006, 11:25 PM   #6
mr.wilson
I meant overdrive.
Wilson
Old 09-26-2006, 11:41 PM   #7
CG
BlahBlahBlah
gear vendors overdrive
Old 09-27-2006, 01:00 AM   #8
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
A good 700R4 is easy to put in and the overdrive can be hooked up with a kit or a toggle switch....Just get a newer model so you dont have front pump issues, I think every one made after 92 was corrected. Overdrive is great as long as you use it properly.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 09-27-2006, 01:08 AM   #9
8696steve
Junior Member
8696steve's Avatar
700r4, if you want lock up then you have to wire it and have the correct torque converter. very easy to install. best tranny I have ever had.
8696steve is offline   Reply With Quote
Old 09-27-2006, 03:24 AM   #10
junkyardjohn
junkyardjohn's Avatar
I'M WITH CG ON THIS ONE. A T-400 WITH A GEAR VENDORS BEHIND IT. THE BEST OF BOTH WORLDS. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
