09-26-2006, 04:25 PM | #1 |
Sb 400 club
2000 Tahoe Front wheel hub replacement
Well i know that this is a commen Prolem on 4x4's. This tahoe is a 2000 with 115k on it and there was a funny nosie comming from the front end. sounded like a bearing and since it was going in today to get the tranny flushed we figured we could have the dealer check it out. And i was right it was the front drivers side wheel hub. Now they want 582$ to replace the hu. I have done it on a jeep before so i think i would have n problem doing it on the tahoe. Any special tools i would need? A torque wrench, and a hub puler should do right?
Any tips or tricks to doing these?
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
10-02-2006, 12:13 AM | #2 |
Sb 400 club
Re: 2000 Tahoe Front wheel hub replacement
no high milage 4x4 out there with this problem?
10-02-2006, 01:59 AM | #3 |
No special tools... just time and beer.
10-03-2006, 05:42 PM | #4 |
Sb 400 club
ha ha yeah. well are the calipers held on with tork drive? I don't have any so i will need to know the size to get one. Thanks
10-03-2006, 07:29 PM | #5 |
He's got mean nasty FANGS!
Caliper brackets should be held on with 18mm head bolts. The back of the hub has 3 15mm bolts, and I forget the size of the 4x4 axle nut.
On jackstands it shouldn't take more than an hour or two to get off, hardest part is getting the 3 bolts that hold the hub one off. With air tools and a lift I can do them in around 45 minutes or less.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
10-03-2006, 08:28 PM | #6 |
Sb 400 club
Head bolts? so am i to belive they are regular or are the special? i am not up on my lingo. I was thinking about trying to lossen the 3 bolts while the truck was on the ground so i can really lay into them. i hate working on stands cause i don't truck them. I have the tools i think and i need the hub puller right?
Thanks it is my dads truck so normally don't work on it if you can't tell
10-03-2006, 09:29 PM | #7 |
Happy to be here
I think he means "hex" head bolts...
10-03-2006, 09:39 PM | #8 |
chevy72402 under a new name to get past a ban
you won't need a hub puller just a big hammer and a punch, make sure not to damage the axle. When installing it clean the rust and dirt from where the old bearing was and install the bearing by using the 3 bolts on the backside. make sure you route your wiring correctly and that the hub assembly is positioned the way you took the old one out. good luck, it is pretty simple though..
10-04-2006, 04:53 PM | #9 |
Sb 400 club
thanks N2 and blue, i thpought they were hex head. Well i ordered the parts today hopefully they are in by this saturday
