Old 08-13-2002, 08:53 AM   #1
71jwalker
center support bearing
Has any body ever had the mounting bolts pull out of the Center support bearing on the drive shaft? After letting my Son drive my truck for a few days, I was coming home last night and I found out that the Bearing had the mounting bolts pulled out. now I have to get a new one pressed on.
Jim:
71jwalker is offline   Reply With Quote
Old 08-13-2002, 10:57 AM   #2
Old Dave
Is a bullfrog waterproof?
Old Dave's Avatar
Never heard of this one before if the mt. bolts were tight to begin with. Suggest not letting the son borrow it again
Old Dave is offline   Reply With Quote
Old 08-13-2002, 03:11 PM   #3
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Never heard of that..
If your son was driving hard and dumping the clutch, he would have tore the rubber bushing.
The bolts were probsbly loose to begin with.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 08-13-2002, 03:23 PM   #4
slam33
slam33's Avatar
It's really not a press fit. You will find a bolt behind the bearing that holds the yoke on. Loosen the bolt, let it just sit to the side there, slip off the yoke and the old support and slide on the new one.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
