Quick question, need a quick answer
What's the torque specs on the 4 nuts that hold down the carb. to intake? The carb is an Edelbrock 600cfm electric choke and the intake is an Edelbrock as well.
Re: Quick question, need a quick answer
I don`t torque 'em.
I've never in my life torqued down a carb....never been necessary, I would think that the only time it is really critical is if your plumbing in a turbo. I normally just short handle the ratchet or whatever I'm using, what I mean is, I place my palm over the socket end of the ratchet and tighten with only the strength of my palm.
That's what I meant, about how much do you tighten the nuts/bolts, sorry for the confusion. Thanks for the info.
it's O.K., I live that way (confused)
Fabricate till you "puke"
Snug, with a short wrench.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
its all about the +6 inches
spin the nut down to finger tight, then 1/4 turn more.
That's how i've always done it. If you have a thick gasket, like what is found under some quadra jets, then maybe a 1/2 turn. You can always snug it more, but once you go to far, you're screwed. |
