Old 09-27-2006, 09:06 PM   #1
ain't_done_yet
and won't ever be
ain't_done_yet's Avatar
Hesitation in '99 Suburban 5.7:
Need some help here...I have a 1999 Suburban w/113K on it. EVERYTHING has been serviced (that I can think of) but when you get in it first thing in the A.M., it hesitates when you first accelerate (for about 2-4 seconds.) Kind of like it's missing or flooding out. Outside temperature doesn't seem to make a difference. It runs like a champ after that first hesitation. Any help would be great!!!
'82 SWB 1/2T Silverado (project)
'96 SWB 1/2T Silverado, factory leather, Sony CD, Sirius Satellite
2006 Ram 3500 Megacab 4x4 SRW, AMSOIL/Injen CAI, AMSOIL By-Pass, Mag-Hytech cover, AMSOIL Lubriants throughout, and much more!!
CHANGE YOUR MIND...NOT YOUR OIL
ain't_done_yet is offline   Reply With Quote
Old 09-30-2006, 05:12 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Hesitation in '99 Suburban 5.7:
When you say "EVERYTHING has been serviced " what does that include? Have you had the injectors cleaned? Rough idle and surging can be dirty or sticky injectors. If you haven't changed your fuel filter try that first. If that doesn't help consider a fuel system flush and injectors clean up.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-30-2006, 09:22 PM   #3
ain't_done_yet
and won't ever be
Thank you for your response!
I haven't actually had the injectors serviced, but I have been running AMSOIL fuel injector cleaner for about two years now (other brands B4 AMSOIL). The idle is actually smooth, just hesitates when you first accelerate. Also, I've replaced the fuel filter numerous times (WIX), and I have even replaced fuel pump (AC Delco)(that was fun).
I just recently had the trans serviced 'cause the wife said it was shifting hard. I think this is something common on this truck. The trans guy said it was still throwing a code, so I may run it down to my buds at Oreilly's and have 'em check it out.
Old 10-05-2006, 08:51 AM   #4
bluewhitepete
chevy72402 under a new name to get past a ban
try cleaning your throttle body. sometimes you get build up in there and it can cause hesitation, have you done a full tune up on it lately?
bluewhitepete is offline   Reply With Quote
Old 10-05-2006, 10:45 AM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
Mine does the exact same thing (2000 Z71). BUT if I let it warm up before I take off it doesn't do it, but I never get up early enough to let the truck warm up
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-05-2006, 11:31 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Ok, my mistake here. I saw it was a 99 but didn't notice you said 5.7. I was thinking 5.3.
bluewhitepete is correct. If it stumbles at take off then it can be a sticking butterfly in the throttle body. They get a bit of carbon build that makes them bind just a bit when they first open. I had one that the shaft on the TB was causing the problem. I lubed the external linkage and it smoothed out.
See if that helps.
Articles-
"Refining Sierra"
Old 10-06-2006, 08:38 AM   #7
Jonboy
Slots go on anything!
Also check your EGR valve. The hesitation off idle can also be traced to a sticking egr valve.
Old 10-06-2006, 09:33 AM   #8
ain't_done_yet
and won't ever be
Where is the EGR? That's one thing I haven't done, but have thought about. Is it easy to replace? How about $$
Thanks, Clay
Old 10-06-2006, 05:28 PM   #9
Jonboy
It is on the intake, but not sure where.
