Rubberized Undercoat Removal
What is the best way to strip Rubberized Undercoat off a frame? I tried to use some heavy duty aircraft stripper but, it is wicked messy. Would sandblasting work?
Aluminum slot wheels rule...
Re: Rubberized Undercoat Removal
Let some paint thinner soak on it, that will loosen it up. Probably gas will peel it off.
"Trucks with Class"
![]() Join Date: Jul 2000
Heat gun & scrapers.
When you get most off you can clean it up with solvent (gas explodes!) or sand blasting. |
![]() Join Date: Jul 2004
Kerosene - thats the magic stuff, leave it soak and melt that stuff right off !!! Diesel fuel should work to but smells a little worse.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Rolled on Paint Club
![]() Join Date: Jan 2006
I scraped what I could off with a putty knife then scrubbed the rest off with a ScotchBrite pad frequently dipped in a bucket of mineral spirits. Wear gloves
![]() Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
#6 | |
![]() Join Date: Mar 2006
1986 C10 - LWB, 305/700r4, posi, vortec heads |
