rear spring help please
I have a 69 1/2 ton 2wd
the front end is from an 84 deisel with a 6.2 I have not set the front end down but I know for sure that the 350 that is in my truck is much lighter than the 6.2 that the springs in my front suspention were designed for I really dont mind the truck sitting a little high in the front end but I have to do something with the rear end before I put the bed back on the truck. will the 3/4 ton HD springs make my truck sit a bit higher in the rear and if not what do I have to do to make the truck sit level thank you |
Re: rear spring help please
I guess what I am asking is if the rear of the truck will raise up any higher with the 3/4 ton HD springs
It's hard to say for sure but it should. The ride though won't be all that great.
I would image it will be really stiff, as for level, there is no telling how it will settle.
