Old 09-29-2006, 09:34 AM   #1
phlegm
Still Green but learning
phlegm's Avatar
AC locked up this summer, do I need to flush
My compressor locked up this summer, I thought the clutch hub went bad but when I replaced it it ended up being the entire unit. Do I need to do a complete flush of the system before closing it up with a new compressor and charging? I am wondering about any metal that may have been discharged when it locked up.
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 09-29-2006, 10:39 AM   #2
cdowns
cdowns's Avatar
Re: AC locked up this summer, do I need to flush
since it going to be apart and open i'd say do a system flush b-4 recharging
Old 09-29-2006, 12:05 PM   #3
70rs/ss
70rs/ss's Avatar
Yeah, if there is any chance the aluminum shavings from the pistons locking up got into the system, it is just piece of mind to flush and be sure. They usually push metal around be fore they finally to the death lock.
70rs/ss is offline   Reply With Quote
Old 09-29-2006, 02:31 PM   #4
69rut
You might want to replace the dryer also. I think they act as filters.
trailers are for boats
69rut is offline   Reply With Quote
Old 09-29-2006, 03:08 PM   #5
phlegm
phlegm's Avatar
How much $$ can I expect on this? I am thinking of getting the dryer and Compressor and mounting htem myself before taking it to the AC guy to flush. Then shoud I add the coolant and oil myself on a backyard job or have the mech do it since he is standing right there.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 09-29-2006, 03:36 PM   #6
Aarons72s
Compressors usually run about $100 to $200 depending on where you get them. You should be able to get one from any parts house. The dryers usally run about 55 dollars. Hope this helps.
Aarons72s is offline   Reply With Quote
Old 09-29-2006, 03:44 PM   #7
phlegm
phlegm's Avatar
How about a flush? any idea how much those run. I also am a little nervous about charging the system myslef but from what I can gather its not that big a deal with the new coolant, and the guages come on the bottles now from what I see .... or am I an idiot? please be honest I have thick skin lol.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 09-29-2006, 03:52 PM   #8
jsbgump
Gone Fishing
jsbgump's Avatar
I would flush the a/c system anytime it has a compressor failure
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 09-29-2006, 04:41 PM   #9
john
member #16
john's Avatar
What I did was pull the condenser and all the lines and flush them out of the truck. Always use a new dryer when there has been a problem or it has been open to atmosphere for a time. You can buy A/C flush at parts house. With the condenser out you can flush it easily several times to get all the junk out. I guess the dryer should catch all the metal. Mine has been 8 yrs now with no probs.
john is offline   Reply With Quote
Old 09-29-2006, 06:17 PM   #10
clay68c10
clay68c10's Avatar
Any restriction in the system can hold the aluminum debris. At work we replace the dryer and expansion valve, separate the easy to access connections and flush ALL of it. If it were my stuff, I'd try to clean out the e-valve and reuse it. I guess you should clean out the POA valve too. With both of those off the evap, it will be easy to flush it out.
You could call that overly cautious, but at work if it shells again we do it the second time for free...
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-29-2006, 08:50 PM   #11
Aarons72s
The only hard part is putting a vacum on the system. I think most shops will do it for a nominal fee. Just remember to replace the o rings at every junction you open.
Old 09-29-2006, 09:21 PM   #12
project1971
project1971's Avatar
Yes you should flush the system when it shells. You can flush it yourself if you have an air compressor. You also need to replace the orfice valve, just a few dollers but when the compressor shells this is the first place any metal goes. To flush the system get a can or two of brake cleaner, spray the brake cleaner in the high side line from the compressor, and then stick a rubber tip air gun in the line and a rag on the other open in to catch all the crap being blown out. Do this several times until nothing else comes out. I do this on everyone I do and have yet to have one come back, 16 years now. Just remember to keep the air blowing through a little while to get everything out. If compressor shells you need to replace the compressor,dryer, and orfice. You should be able to clean everything else, it in doubt about metal in it, replace it. Hope this helps
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
Old 10-01-2006, 01:18 PM   #13
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Yes you must flush the system, especially if you want to have any warranty on the compressor, they require you to flush, install new receiver/drier, orfice tube or POA/ expansion valve anytime you install a new compressor. And usually you have have to have proof that it was flushed, like a bill from an auto repair shop showing a system flush.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 10-06-2006, 02:38 PM   #14
phlegm
phlegm's Avatar
is the POA and the orfice valve the same thing?
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 10-06-2006, 05:47 PM   #15
Firefighter
Expansion valve or orfice whichever it has, usually expansion on older trucks.
Yellville, Ar. USA
