I'm thinking about swapping hoods on my 72 to a 67. Will i need to swap fenders also? Will my 72 grill surround work with the 67 hood. I think the 67 hood looks great on lowered trucks.
On a side note, back in the early to mid 90's there was a 67-72 truck that was red, black with silver graphics. Had a phantom grill and the first 18+" rims I had seen on this year truck. It was a regular in classic truckin' and other rags of the type. Anybody know which vehicle I am refering to? Anybody have pics or info on it? |
Re: Hood and fender compatibility 67 on a 72?
The whole front clip, including the rad support is different.
Rottenwood Garage Member
67-72 GMC front clips and 67-68 Chevy you can do some swapping.
69-72 Chevy are interchangable only with each other........ Now I do have a yard truck that is a 72 and it has a GMC hood on it that fits correctly...so go figure?!!?! Last edited by 72freak; 09-29-2006 at 03:48 PM. |
well the gmc and chevy hoods are the exact same thing except with different badging
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
its all about the +6 inches
with exception to trim holes... 67/68 hoods are the same GMC or Chevy
With exception to trim holes, 69 - 72 hoods are the same GMC or Chevy. I have a 71/72 hood on my 69 GMC front clip. In order to run a chevy grill; if you want the 67/68 hood, you'll have to run 67/68 fenders (or hire a heluva body man and pay him stupid money to graft the old nose on the new hood) In order to run the 67/68 fenders, you'll need a 67/68 core support, and grill. If you want a GMC grill, you'll need a 67/68 grill and top bar (actually any GMC grill with the 67/68 top bar) and core support. Any year GMC fenders can be used. 68 - 72 used the same fenders on the GMC side of the house... and that fender is the same as 68 chevy. Did this help, or did it add to the confusion? |
Hollywood
That red, black & silver truck you were asking about.....was the Traders built truck. It was awsome and I still have the centerfold from truckin mag with it. It was sooo cool with the shaved drip rails and all the other mods for it's time. If I get a chance, I will scan it and see how it turns out.
you don't have to change out the core support, with a few holes drilled for the front splash pan or filler panel, the piece that goes between the core support and bumber on the 67-68 chevy. Other wise they are functional the same.
Get a 67-68 hood, latch assembly, brace, fenders, grill and filler panel if you want GMC then you have to get a different core support because of the dual headlights. Or modify for the GMC style headlight buckets. |
Woof?
'71-2 headlights stick out farther than '67-68. They have pieces (buckets, like the GMC) welded over the stock headlight holes. To use the '71-2 radiator support with a '67-8 front clip, you'd have to remove those.
1968 LWB CST BB 2004 Avalanche Z71 LT3. 2003 S-10 ZR2 (hers). 1997 Astro 1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck. 1997 Saturn - need gas mileage from something! |
ah the one thing I didn't pick up on. I have mocked up the 72 core support to use the 67-68 fenders and hood but not the head light doors
Sorry for the incomplete information |
I had thought there was a difference... isn't the 69 & up one a but taller too?
Woof?
I don't think so. I ended up using (I think) a '69 GMC support in my first '68 project truck. It was the only rustless support I could find in the junkyard, so I nabbed it. I cut off the 4 light buckets, and it fit in with no problems. I know the factory holes for *everything* to fit a '67-8 are found in the newer trucks, behind the outer brackets. Even the square holes for the adjustment screws are there.
1968 LWB CST BB 2004 Avalanche Z71 LT3. 2003 S-10 ZR2 (hers). 1997 Astro 1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck. 1997 Saturn - need gas mileage from something! Last edited by Werewolf; 10-01-2006 at 04:41 PM. |
#13 |
man... i was trying not to learn anything today.
#14 |
Woof?
Sorry.
#15 |
I had a rusted out 68 core support sitting and i was putting together a 72 front end and sat the 72 core support right beside it. That's when I started comparing them other than a few small items they were the same. So I stopped looking for good 67-68 core supports and have 2 67-68 trucks that I have bolted together using the later core support. I thank were wolf for pointing out the one difference I missed. I was out at the shop today though and had to recheck! lol
#16 | |
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#17 |
![]() Join Date: Mar 2006
Newbie here, so I'm just trying to make sense of this... What all is needed to run 67-68 GMC style front clip on a 69 GMC?
#18 | |
A guy with a truck
-Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#19 |
Woof?
Not really a GMC guy, however, I *think* they're identical already. Maybe the hood is the newer style, I forget. If you do a board search, you should come across something. I saw a thread a long time ago, before the boards switched formats, about the differences between the years as far as GMC's go.
#20 |
Woof?
D'oh. Was close.
