Old 09-30-2006, 06:34 PM   #1
chevyboy55
chevyboy55's Avatar
100 amp alternator question
I just did the 100 amp alternator with internal regulator conversion. My question is, can I remove the plug that went into the old external regulator?
I followed Toodtheodd's directions in the FAQ's here's the part I'm wondering about.
chevyboy55 is offline   Reply With Quote
Old 09-30-2006, 08:17 PM   #2
daveo68
daveo68's Avatar
Re: 100 amp alternator question
I think you have to leave the plug on it ,because one of the wires gives you more resistance to ammeter or idiot light to make alternator charge right.
68 C-10 Custom LWB
307 V8
Lexington,NC
davideowens@lexcominc.net
God Bless America
daveo68 is offline   Reply With Quote
Old 09-30-2006, 09:45 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The answer is yes you can eliminate the plug and the external regulator.
This website will tell you all about it. http://www.chevelles.com/techref/tecref14.html
The brown wire is the charge wire from the idiot light and the blue wire just extends it from the external regulator to the alternator. You can eliminate the blue wire and just run the brown wire to the alternator. The white wire isn't used and the red wire is the power wire to the alternator. It should go to the positive battery terminal.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
