Old 10-01-2006, 01:19 PM   #1
1969C/10
Unskilled Labor
1969C/10's Avatar
Removing Door Panels
I'm having trouble rolling up my windows so I want to take a look at them. I already took off the arm rest and screws at the bottom of the panel. How do I take off the inside door handel and window handel? After I remove those does the panel just pop off? Thanks.
1986 K/20, 350/TH400, My First 4x4.......
1969C/10 is offline   Reply With Quote
Old 10-01-2006, 01:21 PM   #2
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Re: Removing Door Panels
There is an inexpensive tool which slides behind the handles and removes the clips. Then you should be all set.
Scott Webster is offline   Reply With Quote
Old 10-01-2006, 01:23 PM   #3
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
There is a little spring clip on the handles, they make a tool to remove them, or I have just used a small flat blade screwdriver to pop the clips loose. then the panel should come right off.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 10-01-2006, 01:40 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I have one of these http://bradystools.stores.yahoo.net/dohaandwilir.html , works better than a screwdriver, and less chance of losing the little spring clip.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 10-01-2006, 02:00 PM   #5
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
That clip is a bia to get back in too!
Pl4yboy is offline   Reply With Quote
Old 10-01-2006, 02:43 PM   #6
Firefighter
Installing the clip is simple just put it on the handle, then push the handle over the shaft, it pops right on
Yellville, Ar. USA
Old 10-01-2006, 02:53 PM   #7
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
I didn't use this method the first time I tried to put the handles back on and it was a complete PITA!! After I found out the easy way the 2nd time it was a snap. Just pop them on the handles and then pop the handle on the shaft and they lock in place.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 10-01-2006, 03:00 PM   #8
watahyahknow
watahyahknow's Avatar
theres a little trick for those clips to get them off without damaging the panel , wish works on newer opelmodels (also gm) use a towel hold both ends so the towel is hanging get it behind the windowcrank and pull back and forth while holding it against the axle of the windowcrank and pulling it slightly off the panel .
if done corectly the clip wil hook on the cloth and pull away from the crank and you pull the crank off in one go , might need to try it a bit and there is a chance the clip will fly away and you need to get on hands and knees to find it back
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
