Starter won't stop
Okay, did a search but didn't find what I was looking for or someone having a similar problem. Seems like the common problem is the starter won't go, instead of going all the time.
![]() I replaced the starter on my 71 c10 with stock 350 and TH350. The new starter works fine, with the exception of if the engine doesn't fire and start, the starter won't shut off. I thought maybe it was the ignition switch, so replaced that, but it still happens. I went through and cleaned the battery terminals, took off and cleaned the battery cable connections at the starter and block, replaced what looked like some iffy wires down to the starter from where the purple branched off to the coil and the starter, along with the yellow wire. Any suggestions on what else to dig into? Thanks, Scott
------------------------------------------------ I say it's only money, my wife says it's only a truck.... '71 C10 Deluxe, factory ac, ps, pb, should be done by 2102 Longmont, CO husker95@hotmail.com |
Re: Starter won't stop
The starter is too close to the flywheel. If it starts, the engine throws the bendix back. Install a starter shim and it will be fixed. The shims are available at the parts stores. Motormite makes them. They will be in a red package and will say HELP across the top.
The place where you made your stand never mattered. Only that you were there... and still on your feet.
Stephen King |
Thanks! I actually have some shims from the 70 laying around, so I'll try those and give it a whirl.
Thanks, Scott
No problem. Post a reply and let me know if that works!!
Stephen King |
Woof?
My dad's starter went bad on his '71 after a week's vacation. He went to start it and back it out of the garage, and the starter wouldn't quit or disengage. The truck did fire, I believe, and the starter still refused to disengage. I'm not sure, though, as it was a long time ago, and if it did fire, my dad cut it off immediately. I just know it ended with the starter freezing, the battery cables turning red hot, and us almost having a blown-up battery in our faces.
Be careful!
1968 LWB CST BB 2004 Avalanche Z71 LT3. 2003 S-10 ZR2 (hers). 1997 Astro 1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck. 1997 Saturn - need gas mileage from something! |
Did you make sure to connect the wires to the right terminals on the silonoid? The purple to the start and the yellow to the run?
Yep, originally had them switched, and the starter wouldn't turn, and that's one reason I had to replace the yellow wire, since it started smoking.
Location: vacaville ca, because it as far from indy as i can be
is the + wire touching one of the terminal wires at the starter?
![]() Join Date: Aug 2001
Sounds Like A Bad Solenoid On The Starter. Pretty Common. Try Another Starter.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
I had a starter pinion gear over-run the ring gear, which, effectively holds the solenoid in the start position - with the key off. I won't go into the flaming aftermath story.
Shims should help. - Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
Sorry, finally freed up enough time to work on the truck again.
Put 3 shims in with no change. Going to go and reconfirm the wiring and put a volt meter on it to confirm that the voltage is shutting off when the switch is turned off. I'll also dig up some more shims and shim it out some more or until the gear doesn't engage the flywheel correctly, whichever comes first. Stay tuned and I'll let you know what happens. Scott
Okay, I confirmed that it's a binding issue, but no amount of shims will fix it. I put in about 1/2" of shims and it's still doing it. I took the starter out and clamped it to a cinder block and it works fine as long as it's not mounted. I'll take it back out and compare it to the old one to see if there is any difference.
So in the meantime since I got tired of laying on the ground I redid my valve cover and intake gaskets and replaced all my vaccumn hoses. Scott
#13 | |
Avatar is a pic of "Before"... Just wait.. ---------------- 1969 Fleetside: Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans. 20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit). Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all ---------------- Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!! ![]() |
#14 |
give us a picture of the front of your selinoid w/ wires on it
