Old 10-01-2006, 06:14 PM   #1
bills68panel
Pulley Problems!!!!!!!!!!!!! Help
Can anyone help? I a'm putting power steering on my 68 panel. I put a 3 ring crank pulley on but now the old 2 ring waterpump pulley is too big to go on. So I looked at a buddy's 70 that came with p/s and his has a smaller waterpump pulley on it.But it is a 3 ring is that for a/c ? if so thats what I want. I'm going to put a/c on next spring. So I started looking for a 3 ring pulley and have no luck what's up with that? help please Bill
bills68panel is offline   Reply With Quote
Old 10-01-2006, 08:31 PM   #2
soulman67
Randy churchill
soulman67's Avatar
Re: Pulley Problems!!!!!!!!!!!!! Help
my 67 has a small 3 groove crank pulley and the big single groove pulley on the water pump. It came with power steering from the fatory. The ac was a dealer installed under dash unit. The crank pulley is small and cast iron I'll have to look and see if it has a part number on it.
1983 GMC K2500 6.2 diesel 4" lift on 35x12.50 tires
2008 GMC 2500HD 6.6 diesel 3" lift on 315 75 16X10
2003 Jeep Rubicon 4.5" short arm lift
1985 Jeep CJ7 30k in parts and still adding up
soulman67 is offline   Reply With Quote
Old 10-02-2006, 02:33 PM   #3
see ten
WTB this ad
see ten's Avatar
A 2 groove water pump and a 3 groove crank pulley should have you good to go for A/C and power steering. You might try ebay for pulley sets. Some of these old trucks have more than one pulley that you combine to build the 2 or 3 groove for the crank. Also make sure they are coming off the same kind of engine (short or long water pump).
see ten is offline   Reply With Quote
Old 10-02-2006, 03:22 PM   #4
cdowns
cdowns's Avatar
i believe the crank pulleys on my 71 was a 2groove plus a 1groove making 3grooves with the 2 pulleys
Old 10-02-2006, 07:35 PM   #5
bills68panel
thanks for your help
Old 10-02-2006, 07:36 PM   #6
bills68panel
thanks a lot the pic really helped
