10-02-2006, 12:12 AM | #1 |
40" MTRs on 71
scored a set of 40" MTRs today. Also scored a 1" body lift for cheap. Need body mounts and put those on and some fender trimming. Thinking of parting out the truggy and putting the 454, th400, doubler, d60, and 14ff in the 71 now
10-02-2006, 01:17 AM | #2 |
Re: 40" MTRs on 71
score
i run mtrs and love them Last edited by kylejamers; 10-02-2006 at 01:17 AM. |
10-02-2006, 01:37 AM | #3 |
Re: 40" MTRs on 71
thinking i will trim like this. Opnions or comments or prom ya'll have run into? Also get some of those universal rubber wheel well flairs to cover cut and keep most off rig.
10-02-2006, 06:07 AM | #4 |
Re: 40" MTRs on 71
Cutting on the yellow lines won't be enough with your current lift if your going to wheel it hard and I suspect/hope you will.
10-02-2006, 06:40 AM | #5 |
Re: 40" MTRs on 71
Alot depends on how flexy your suspension is but...
The mods I'd recommend before the hard core wheeling trips would be these: *Remove the inner fenders, they're going to hit/rub. *Have at least 8" of lift along with the metal trimming. *Rear drive shaft will want to have a double cardon joint for the amount lift needed. *Front shaft will be happier with 1410 yolks and at least a 12" slip joint in it. *Beefing up the front axles won't hurt either, going to some 4340 shaft's and upgraded u-joint's is worth thinking about. *Rear disc's could be on the 'later' list. *Some sort of hydro steering, assist or full w/cooler. *High steer kit. *Quality diff covers. Installing the 454, doubler and th-400 should now be at the top of the list! |
10-02-2006, 07:01 AM | #6 |
Re: 40" MTRs on 71
Vt has 42s and has been tweaking all the bugs from the po and just generally making his rig offroad worthy over this summer.Kurt,why not post a picture or two to give an idea of the required "loss of sheetmetal" required.It always seems to be more than you think and I know yours has seen the "trail-test".
That thing looks tough.How much lift on it now?I want to see your truggy.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-02-2006 at 07:04 AM. |
10-02-2006, 07:07 AM | #7 |
Re: 40" MTRs on 71
[QUOTE=special-K;1817986]Vt has 42sQUOTE]
40's bud. Very similar to what MNoby's building/going for. |
10-02-2006, 07:15 AM | #8 |
Re: 40" MTRs on 71
Currently I have 4" springs in front with a zero rate moving azle forward 1.5" and one inner fender is already MIA. Rear is 56" springs with a shakle flip. If I put my truggy stuff in it then t will also aquire my d60 front with crossover steering and hydro assist 4.56 gears and locright and my rear 14FF with 4.56s detroit and disk brakes. I put together a 1350 driveshaft with 8" slip on the rear with its current config and have a 1350 dodge cummins CV shaft to make work for a front. I also scored a 1" BL yesterday too so with that and new body mount I bet I will get another 1.5" of fender clearance being half the body mounts are gone and the rest are smashed down. Might also put 52s in front. I ran my 83 shortbox with 40s on only 4" and hacked fenders for about a year. Rubbed cab was the only thing at stuff/ turn
10-02-2006, 07:39 AM | #9 |
Re: 40" MTRs on 71
You got it covered.
10-02-2006, 08:22 AM | #10 |
Re: 40" MTRs on 71
Sounds awesome!I ran 13.50/37 Swampers w/8" rims on a `71 w/4" springs & 3" body lift and that cleared fine w/o cutting sheetmetal.On another`71,I ran 14.50/37x16.5 Armstrong Extra Tractions w/9.75" rims w/4" springs and cut the body like you show and that cleared fine,too.You should be fine,I think.You can always cut a little more if you need,right?Keep us up on the progress.
10-02-2006, 06:39 PM | #11 |
SWB 4x4 Collector
Re: 40" MTRs on 71
I did a little something on paint for you and clean up where you had the yellow lines.....
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
10-02-2006, 07:06 PM | #12 |
Re: 40" MTRs on 71
close... a little more like this-ish
10-03-2006, 07:26 PM | #13 |
Cereal Killer
Re: 40" MTRs on 71
the cage needs to be a little taller and go as far back as possible in my opinion. hoop style safari look or big ass halo trendy look. maybe a little bob would be cool but the oem butt needs to be reused. plate it at the firewall and do a engine/rad cage.
damn dude you got a lot of work to do you better get busy |
10-03-2006, 07:56 PM | #14 |
Re: 40" MTRs on 71
yeah, that was just a quick drawing. Cage will be done the road as getting drivetrain done is priority. I have a fastrac on order so basically I will build the cage as large as possible to fit inside the soft top. Tube work isn't a problem for me as this project is something to keep me wheeling as I finish my buggy. Don't wanna bob this one either like I did my old cab truck (well tappered the ends in) so I can haul 4 people and camping gear etc. I will have the buggy for the extreme stuff unless I get a good offer to sell it then I will uber trick the 71 k5 out...
10-04-2006, 07:08 AM | #15 |
Re: 40" MTRs on 71
How long are you prepared to wait for that top?I guess you can wait since you`re making a project of it.I ordered one for my`90 in July and still waiting.With winter coming,I`m cancelling the top.I`ll be selling it before spring.I figured I`d get a little fall use and it would help it`s appeal when going on sale.I doubt it would add to the price,though.STC needs to get it together.
