Old 10-02-2006, 07:52 AM   #1
Ozona
Big Block Guys - Valvecover question for you:
I'm in the middle of getting my new 509" crate motor ready to go into my 1972 GMC-1500. Question for you guys: Will the OEM/stock / well...repops from classic industries... bbc valve covers fit with roller rockers? The engine has aluminum scorpion roller rockers in it. Looks like a ~2.5" from the top of the lock nut on the rocker to the top of the valve cover rail on the head.
I'd like to use as OEM looking of a valvecover as I can without having clearance problems.
Thanks!
Ozona is offline   Reply With Quote
Old 10-02-2006, 08:01 AM   #2
junkyardjohn
junkyardjohn's Avatar
Re: Big Block Guys - Valvecover question for you:
I've Had Em Fit Ok With Roller Tipped Rockers, But With Full Roller Rockers I've Had To Use Taller Valve Covers. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 10-02-2006, 10:20 AM   #3
69CvyPickup4x
69CvyPickup4x's Avatar
saw a guy use thicker gaskets and he said it works but i dont know
69CvyPickup4x is offline   Reply With Quote
Old 10-02-2006, 10:27 AM   #4
CMars45000
CMars45000's Avatar
no you can not fit full roller rockers under stock valve covers...You can try to double up on the thick gasket or you can get a valve cover spacer from like Moroso, Stef's or Milodon...one of those guys not sure whom though....
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 10-02-2006, 11:02 AM   #5
Robznob11
Robznob11's Avatar
you can buy spacers from jeggs or summit, some one relly looking would probably spot them though
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-02-2006, 01:45 PM   #6
Ozona
It's ok if someone really looking sees them, I'm not trying to sneak really, I just like the stock look. The engine has an edelbrock intake on it, just trying to decide whether to paint/powdercoat that to match the motor in chevy orange. I was thinking that the stock style valvecovers and coating the intake would make for a neat look..and create some controversy.
Did the big block trucks have the same air cleaner assembly as the small block trucks, or was it unique?
Thanks for the scoop on the valvecovers...I'll see what I can come up with. I don't want to double up gaskets if I can help it since that just sounds like a leak waiting to happen.
