08-13-2002, 03:02 PM | #1 |
gas tank
hi
have a problem filling tank--will only take gas with pump running very slow put a suburban tank [67/72] poly in rear of truck---it had a 1 1/4 od intake--ran pvc pipe the rest of way to boatfill in side of step fender--have 2 vent pipes any help 4" -----fender - 10" - tank------ 12" thanks--bob |
08-13-2002, 04:19 PM | #2 |
you have to vent the air out so it don't come back up the fill line.
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
08-13-2002, 05:26 PM | #3 |
hi
have 2 vent lines---that is what i though was the problem at first thanks -- bob |
08-13-2002, 05:44 PM | #4 |
Slowly getting CRSS...
i kinda have the same prolblem expcept its b/c mines in the rear tailight. You do not have enough gravity working for you to get the gas down the tube, you need to raise the filler opening to a higher point above the tank and make sure there is no dips in your filler line where gas can pull as this makes filling a slower process. It used to take me a good solid 15 min to fill the 21 gal tank
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
08-13-2002, 06:26 PM | #5 |
sounds like you've got enough venting, but any bends in the line would be an area to check.... anything you can do to create a straight line to the tank is optimum... any bends in the line should be gradual.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
08-13-2002, 06:46 PM | #6 |
Led Sled! Discs R 4 ME!
PVC??????????
What kind of pvc did you use?
Gas will eat white pvc. Make sure it's rated for gas! Also it would only take a few angles in the the pipe to cause this. another option is to get a long boat gas filler hose in place of the pvc and use gentle curves in the hose and it should be fine. Keep any low pitched lengths to a minimum. Denny |
08-13-2002, 07:33 PM | #7 |
hi
intake is about 10" above tank with a 45--dropping to another 45 with about 10 " of straight into tank thanks all for help--bob |
