Old 10-02-2006, 08:57 PM   #1
donzoidz
Chevy Van timing 6-250 Help!!
I have a 1970 van which has 2 different timing marks. 1 between the pulleys and one on the bottom of the oil pan. I cant read the one between the pulleys and when I hook the timing light up to the #1 cylinder it doesnt show the mark where its supposed to be??? What am I doing wrong guys??
donzoidz is offline   Reply With Quote
Old 10-03-2006, 03:52 AM   #2
JimKshortstep4x4
Re: Chevy Van timing 6-250 Help!!
Welcome to the group from West Michigan!
Did you disconnect the vacuum line to the distributor?
Jim
Old 10-03-2006, 10:28 AM   #3
donzoidz
yes , idle at 800 rpm .. I think to be able to see it I need to put the pick up on a different plug wire?
Old 10-03-2006, 12:20 PM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
You should be on #1 plug, take a piece of chalk and scribe the line on the harmonic balancer to help you see it better
sneakysnake is offline   Reply With Quote
