10-03-2006, 05:13 PM | #1 |
and won't ever be
What order do ya'll recommend??
I hopefully will be getting started on my SWB in January. My problem is, I'm not sure what order to do things in. Here's what I'd like to do:
Make it drivable first....complete new drivetrain. (but should I have the engine compartment cleaned up and painted first?) Am planning on fuel injection. Lower suspension and install new wheels/tires. Would like to install all new components on front end when lowering. Interior Body mods Paint This is the order I'm thinking about. But....the undercarriage needs cleaned up and painted...I'd like to have the frame lookin' good. Any input would be helpful....this will be my first build this in-depth.
'82 SWB 1/2T Silverado (project) '96 SWB 1/2T Silverado, factory leather, Sony CD, Sirius Satellite 2006 Ram 3500 Megacab 4x4 SRW, AMSOIL/Injen CAI, AMSOIL By-Pass, Mag-Hytech cover, AMSOIL Lubriants throughout, and much more!! CHANGE YOUR MIND...NOT YOUR OIL |
10-03-2006, 05:37 PM | #2 |
www.73-87chevytrucks.com
Re: What order do ya'll recommend??
I would change all the fluids out first. Checking the brake wear, steering wear, tires/alignment, u-joints, wheel bearings, door hinges, strikers/latches...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
10-04-2006, 09:28 AM | #3 |
Insert Witty Text Here
I guess it depends a lot on your goals. I have found, through experience, that I tend to lose momentum after I start on a major project. A good example would be my cam change fiasco.
I did a cam swap. It started out simple, and grew huge. I ended up sandblasting and painting the intake and every bracket on the engine, I replaced every gasket except the rear main seal and the head gaskets. The engine got cleaned up and painted. I degreased everything under the hood, and repainted everything I could. I replaced the brake lines, motor mounts, fuel pump, radiator insulators, vacuum lines, belts, hoses, and everything that I touched during the project. Everyt time I pulled a part, I could see another that was never going to be easier to replace. I just kept getting further and further into it. Unfortunately, as the scope of the project grew, I lost momentum. It was hard to stay excited about a truck that I couldn't drive. In the end, the cam change that was supposed to take a long weekend took ten months. It was a real learning experience for me. Several other folks on here have told me that they have had similar experiences. I suspect that this is why there are usually so many basket case vehicles out there for sale. Keep this in mind as you start going through everything. From this, I have learned to approach my truck as many smaller projects that can each be completed in a shorter amount of time. Being able to drive and enjoy the truck between those projects keeps me more motivated. Slonaker |
10-04-2006, 05:15 PM | #4 |
Sb 400 club
getting it mechanically sound should be your first thing. if pulling the motor repaint the engine bay (best time) As for the chassie weel pullling the box off and a good wire wheel or grinder will clean it in no time. if your going to need to do cab corners that is a good time to. The hardest part to clean is under the cab unless you plan on pulling it also. paint is definatly last. sounds like you got a good plan go for it
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
10-04-2006, 09:58 PM | #5 |
Yeah I second the start small theme. I've been involved in a engine swap for over a year now. Lack of knowledge and laziness at times. I too have shopped for other trucks, and I keep turning down vehicles that aren't much further along in their restorations than mine is. I'm still confident I'll get it finished here soon, but it should have been done months ago(engine swap). Oh, I am doing it all myself, poor me.
10-04-2006, 10:35 PM | #6 |
Stepsides RULE
Well, to me, set priorities first. I'm pretty much going exactly against what my friend 84 400 says. I'm doing body and paint work first because my truck NEEDS bodywork first, its rotting away from underneath me. My 305 is still pulling (albeit in need of a carb) and the transmission is still strong (just leaking a lil') Once I have my truck physically sound, I'll start working on swapping motor/transmission/rearend. Interior is gonna be piece-mill (sp) after I swap cabs. I've already done wheels/tires and suspension drop will occur probably around cab-swap time.
My #1 thing is this is my daily driver. I can't simply pull it apart and start "fixin" things. I have to maintain it first and formost, and as time allows, do one major thing at a time.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
10-05-2006, 01:24 AM | #7 | |
Professional Grade
4 years later, its finally mostly back together, and running... Been feeling really burned out on it recently, if I had the same motivation as when I first started the whole way through, I probally coulda done as much as I've gotten done in 4 years in a year...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
10-05-2006, 11:43 AM | #8 | |
I'm back with 2nd truck!
Sounds so much like me as well guys. First the 79 Big 10 was down for 2 years with a blown engine but got that swapped out and drove it. Now I got the 79 K-5 Blazer and it's not running. Seems like I get one and then drive it but after parking I seem to lose interest or something else comes up where I don't spend the time or $$$ on them.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
