Old 10-03-2006, 07:24 PM   #1
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
rear u bolts where to get them?
i am looking for rear ubolts for my 66 the thick ones!! i would like longer ones because i am going to make either 2'' or 3'' drop blocks does any local parts stores carry them or am i going to have to order them any suggestions thanks!!!
gostranger is offline   Reply With Quote
Old 10-03-2006, 07:49 PM   #2
el curioso
el curioso's Avatar
Re: rear u bolts where to get them?
You may order them or you may go to you local spring shop and have them make you some. What size rim you runnig cuz i belive not sure though that 2" is the limit with 15" wheels and 3" with 16" wheels just incase you get a flat you will drag the ubolts possibly spining out of control, and not roll on the wheel.IMO. Theres a write up in the FAQ section on exactly what it is you need.
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 10-04-2006, 06:26 AM   #3
gostranger
gostranger's Avatar
thanks for the help and i will be running 20'' wheels so no problem with clearance.
Old 10-04-2006, 01:19 PM   #4
gostranger
gostranger's Avatar
none of the local parts stores can give me a u bolt unless i have all of the dementions would anyone have this info?this would be a great help thanks
Old 10-06-2006, 06:08 AM   #5
cdowns
cdowns's Avatar
it might be worth it to you in the long run to buy some measuring tools
Old 10-06-2006, 09:29 AM   #6
Shane
Shane's Avatar
Shane is offline   Reply With Quote
Old 10-06-2006, 11:22 AM   #7
BowTieOgre
Check out THIS thread in the FAQ. Apparently his local shop knew exactly what to do. I would suggest taking in an old Ubolt if possible just to be safe.
So tell me Cdowns, how would you go about measuring something like the Ubolt? Im being serious, I have a tape measure but that would seem to be clumsy and not very accurate. I'm still very much a neophyte in the garage and need all the info i can get.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 10-06-2006, 01:37 PM   #8
Shane
Shane's Avatar
you measure how much longer you need them ... pretty simple actually ... the radius is not going to change, only the length of the legs.
Old 10-06-2006, 02:03 PM   #9
cdowns
cdowns's Avatar
using a caliper or compass with a tape measure you measure the diameter of the rod the diameter of your rear axel tube and length of ubolt // if you know the length already for 3"blocks i'd go about 31/2 inches longer to allow for pinion angle shim you can always cut off the little bit extra
the caliper and compass are great tools to aid in measuring inexpensive and last a long time these were my grandfaters and still get lots of use at close to a hundred years old
Old 10-06-2006, 09:14 PM   #10
el curioso
el curioso's Avatar
If yours are messed up beyond recognition, tell the spring guy you need a pair of 5/8 thread, 24 inch long U-bolts for a 3 inch axle tube. He'll know what to do.
My shop charged me $21.80 for a pair of them
Hope it helps.
Old 10-06-2006, 09:26 PM   #11
gostranger
gostranger's Avatar
thanks for the help from everyone it is great to be able to ask a question and get help from everyone on the forum!!! even if the question seems dumb to some people!
Old 10-09-2006, 02:39 PM   #12
gostranger
gostranger's Avatar
got my ubolts made by fleetcraft $16.98 total they are long enough to do up to 3'' drop!! thanks again for the help!!
Old 10-09-2006, 03:12 PM   #13
Shane
Shane's Avatar
you are getting close to your "scrub line" of potential chassis parts hanging below the wheel with a 3.00" block ... if a tire goes flat, you are in for a hairy ride ... be very careful using 3.00" blocks ...
Old 10-09-2006, 06:50 PM   #14
gostranger
gostranger's Avatar
even if i am running 20'' wheels? i thought there would be plenty of room but i will check it out thanks!
