Old 08-13-2002, 06:28 PM   #1
JReynolds
Farm Truck ran 1/4-Need Help!!!!!
Those of you who have been on the board for a while might remember seeing pictures of the "Farm Truck."
I finally went to New England Dragway, and I could only muster a 15.29, but the top speed was at 98 mph.
My wife was watching from the lights, and she said the rearend came off the ground "several inches". I made another pass, and the same thing happened. I've done plenty of burnouts on the street, and have gotton a bit of wheel hop coming out of them, but nothing like this. Guys at the track couldn't believe the speed verses the time, normally that would be a mid 14 second speed. My question is, what can I do about the wheel hop?
The truck has coil spring rear susp. with new KYB gas shocks.
3.07 rearend, 4 speed. The springs are original-heavy duty coil springs. Any help would be great. Thanks>>>>>
1969 SWB Stepside. 350 w/Vortec heads, 380 H.P., 450 ft/lb dyno proven.
JReynolds is offline   Reply With Quote
Old 08-13-2002, 06:40 PM   #2
68racer
Yeah baby!
68racer's Avatar
There is nothing wrong with the suspension, you need more weight on the rear or slicks. A rear fuel tank really helps or tractor ballast. That trap speed should put you in the 13's, these trucks don't run as fast as cars at the top end because of the lack of aerodynamics.
68racer is offline   Reply With Quote
Old 08-13-2002, 06:48 PM   #3
JReynolds
I have a 3.73 rearend that I bought from CPNE. It is ready to go in, I think I am going to try that to see what happens. My theory being that maybe with the harder launches the rearend might want to stay on the ground better. I don't want to move the tank, and the bed is finished so nicely I really dont want to put anything in it. My other thought was to replace the springs with lighter duty ones. I dont want to go to far with it because I really only go to Epping once or twice a year. What you say about times is encouraging though. I know that on the street I have surprised a few late models!
Old 08-13-2002, 06:59 PM   #4
68racer
Yeah baby!
68racer's Avatar
I use suburban rear springs and get 1.9 second 60' times (with slicks and a 3.73). I think the springs are 3/4 ton, I guess it's the progressive wind just lets it sit back a bit and then no more. What were your 60' times? Check out the girlfriend/burnout post for pic of truck.
Old 08-13-2002, 07:16 PM   #5
JReynolds
I threw my slips away when I got home, so I can't give you my 60' time, but I'm certain that the first 100' or so were pretty pathetic. If I get the same sort of problem after changing the rearend, I'll just try to lauch without any wheel spin at all. I get so amped up at the lights though, it's easier said than done. I dont think slicks would really help me, as the tires werent really spinning, just bouncing....On the street, I can absolutely bake the tires, and come to think of it, maybe I should try one pass doing just that. I remember I was trying not to lose a lot of time spinning, so maybe I was just stuck in between, and should go one way or the other, either all out, or just feather it off the line.
Old 08-13-2002, 07:27 PM   #6
68racer
Yeah baby!
68racer's Avatar
I'd go for the feather approach, but your problem is traction can you borrow slicks? Stud pattern may be a problem. You could fabricate a ballast box to go where the spare wheel should be. It's alot more fun when you can nail it off the line. Deeper gears will make wheelspin worse.
Old 08-13-2002, 08:59 PM   #7
mooneyes
mooneyes's Avatar
i think the 3:73 rear would help greatly..ive had a 4 speed ,..now 3 speed with 3:07 and there a bit tall with a 4 gear it takes off like a mut once your rolling but from a dead stop its pretty harsh
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 08-13-2002, 09:44 PM   #8
smitty62
smitty62's Avatar
I'm not that sharp when it comes to drag racing, but it would seem to me that some experimenting with tire pressure is called for?
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
