Old 10-04-2006, 09:44 AM   #1
Gray Ghost
Gray Ghost's Avatar
Door lock question...
On my 70, the passenger door will not unlock via key. I am hoping this isn't normal. Can anyone tell me [1.] if it is the norm....[2.] If it's not can it be fixed w/o removing the lock cylinder?
Thanks!
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 10-04-2006, 09:55 AM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Door lock question...
Will the lock turn with the key? (When the door is not closed?) If it will, it's a common problem, try pushing in on the door handle a little while turning the key.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-04-2006, 10:12 AM   #3
timcos
Chief Honcho In Charge
timcos's Avatar
My driver side is a bit the same way. The lock know was frozen. I unfroze it. got it m,oving with some wd40. But...the lock fromt he outside will lock the door but not unlock the door.
I think I am going to have to take it apart and unjam it.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 10-04-2006, 10:14 AM   #4
Gray Ghost
Gray Ghost's Avatar
No...the lock won't turn left at all...turns right like a dream though, guess I need to have it worked on.
Kelly
Old 10-04-2006, 10:18 AM   #5
cdowns
cdowns's Avatar
take door panels off and spray the crap out of everything with wd-40 or pb blaster // window regulators and rollers too see if that helps
Old 10-04-2006, 11:19 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
If the previous suggestions don't cure it you could have a bent wafer inside the lock (usually caused from trying to force it to turn) or your key could be worn enough to cause the problem you are seeing. You can also have this problem if you have a big box store or hardware store make a duplicate key for you. Whenever I am making a copy of a key and it is worn excessively I mic the cuts, look it up in my book and cut the new key to factory specs.... Cures most problems.
If you pull the lock out and clean it up good there should be a code # stamped on the lock case or on the locking pawl. (the piece on the end of the lock that contacts the mechanisim inside the door) This is the code number and a new key can be cut from this number by any competent locksmith.
LockDoc
Leon
Old 10-04-2006, 11:51 AM   #7
junkyardjohn
junkyardjohn's Avatar
IT'S A CHEAP FIX. YOU CAN GET A NEW IGNITION & 2 MATCHING DOOR LOCKS FOR AROUND $28. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 10-04-2006, 01:28 PM   #8
timcos
timcos's Avatar
WD40 is the best. I soaked my door workings on Sunday with WD40. I did the door thing this morning and I can unlock and lock my driver door with the key from the outside...Sunday I could not unlock it...in fact the key would have broken off.
Fantastic suff.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 10-04-2006, 01:31 PM   #9
timcos
timcos's Avatar
What is pb blaster?
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 10-04-2006, 01:36 PM   #10
Aarons72s
PB bLaster is a very good rust penatrant. I think I got my last can autozone a few years back. Dont really use the stuff anymore becuse I have undid every rusted bolt on my orange and white from Indianna. And most of the stuff out here comes loose with just plain old wd40. But I do recomend the PB blaster for all of you in the rust belt.
Aaron
Aarons72s is offline   Reply With Quote
Old 10-04-2006, 01:40 PM   #11
timcos
timcos's Avatar
The stuff I learn here.
http://www.pbblaster.com/
Thanks Aaron
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 10-04-2006, 02:00 PM   #12
Aarons72s
No problem.
Aaron
Old 10-04-2006, 05:09 PM   #13
matthufham
i bought brand new matching door and ignition lock cylinders, and my passenger door lock will not lock from the outside, but locks just fine, and works fine from the inside.
matthufham is offline   Reply With Quote
