Stupid question of the day - oil capacity
Friend of mine who has a 350 swore up and down that his engine takes more oil than my 307. I could have swarn they both are the same (4qts). What are the oil capacities?
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree Last edited by farside847; 10-04-2006 at 11:21 AM. |
![]() Join Date: Nov 2004
Re: Stupid question of the day - oil capacity
My 5.3L (2000 Silverado engine) takes exactly 5 quarts for an oil change.
My 350 in the 67 takes 5 1/2 to 6 quarts.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
I Have Never Seen A Small Block Take Less Than 5 Qts If You Change The Filter?
my memory musta been off then, wouldnt be the first time
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
I hear ya on that. I'm only 25 but I think my memory has advanced "old timer's" disease
Java Mechanic
5qts is normal but an aftermarket pan might cause a difference.
In stock form in similar original applications; I'm pretty sure the 307 and 350 take the same amount of oil.
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
Java Mechanic
That is not a small boat you're sitting in there my friend.
#8 | |
Yeah, the 350 has a crappy "aftermarket" pan and it did look a little bigger than my bent up stock one I took off.
5 quarts with stock pan and filter. I sometimes run one of those monster wix 51794 full quart filters. So then it would be 5.5 quarts. Oh here is the other part numbers for the monster filter: AC PF932, CARQUEST 85794, FRAM PH373, NAPA 1794, PUROLATOR L40084.
If you gaot a good motor I would recomend changing to this filter for more oil and filter capacity but they arent cheap about $10. I stoped using them on my green and white cause the motor is on its last miles. Hope this helps. Aaron Last edited by Aarons72s; 10-04-2006 at 02:15 PM. |
Woof?
Hey, cool. Yeah, I'll be getting one of those!
Some 350's took less, like some out of cars. The 350 in my Caprice, as well as the LT-1 in the T/A took 4.5 quarts cuz of the teeny filter they put on those engines for whatever reason. Fortunately there's plenty of clearance for the larger filter. Hopefully there will be plenty for the super-sized version. I once came across a Buick 350 that took only 4 quarts. And the 5.3 in my Avalanche takes 6 quarts. Keep adding until the dipstick says "full!" ![]() Just got reminded... for a 6 quart V8, the Avalanche has the *tiniest* filter on it. Most GM 4's and 6's take bigger filters. What's up with that?
1968 LWB CST BB 2004 Avalanche Z71 LT3. 2003 S-10 ZR2 (hers). 1997 Astro 1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck. 1997 Saturn - need gas mileage from something! Last edited by Werewolf; 10-04-2006 at 08:02 PM. |
