weird elec gremlins in dash bezel
Been a while since i visited, spent 2 days rebuilding my 67 dash bezel,installed a billet insert & painted everything,new bulbs (9),,,plugged it all in & things went nuts,left blinker shows right,,no dash lights at all,gas gauge not working,good fuse,,,,think maybe the printed circuit is bad?
Thought a board member here may have had a similar problem? Mods,,If this needs to be moved to Elec section ,can you move it for me? Thanks JFD |
Re: weird elec gremlins in dash bezel
I cant remember but can the electrical plug be put in backwards? I thought when I have cahnged mine out that yhe pulg on the wiring harness can go on both ways. I always just looked at the plu and saw that on all of them that one terminal wasnt used IE: didnt make contact on the cluster printed circuit and just lined it up that way. Thats my only thought. Any body else have some suggestions for TraderJon?
Aaron |
Could be,,,i think the plug has a snap release on one side,,i'll go crawl under & look?
Thanks Aarons72s |
Make sure your gauge cluster is GROUNDED to the dash metal.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
its all about the +6 inches
did you install a guage inst panel in a dummy light truck?
I didnt think about the ground,,,I just got through checking the power to it,got power,,,,either i'm getting fat (cold bullets)or these cabs shrunk..gotta be a contortionist to get to it.
thanks Jhow Longhorn,,,,,It's a gauge panel,,the original to the truck,,although it has a 68 bed,,,driver door is 72,,,,goodmark hood,,,85 c10 disc brakes,,Monte Carlo tilt..kind of mixture,but it works good. I figure it was something i did while i had it out,,,did notice a bad spot in the circuit,,but everything worked when i pulled it ecept 2 burned bulbs. Thanks JFD |
