Old 10-04-2006, 07:18 PM   #1
Texasdeere
Texasdeere's Avatar
Question Aux Fuel Tank
Does any one have a picture of an aux fuel tank for a 72 longbed truck? It can be installed or uninstalled. Also how much fuel does it hold?
Texasdeere is offline   Reply With Quote
Old 10-07-2006, 06:55 PM   #2
Texasdeere
Texasdeere's Avatar
Re: Aux Fuel Tank
No pictures aye?
Does anyone know where the tank is usually mounted?
Does it fill through a wheel opening?
Is the aux tank a factory option or an aftermarket add on?
Old 10-07-2006, 08:17 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Aux Fuel Tank
there were stock ones, with a filler pipe stickin out the bed side, normally towards the front on the drivers side, but recently saw one listed on the SPID label and it was on the rear portion of the drivers side bed.
there were dealer installed ones (some recent discussion on if they were dealer installed or aftermarket...either way) that was on the driver, or both driver and passenger sides, and had a square stainless door with a lock.
they can easily be removed... I did it on my first truck, a few bolts, cut some hose, and let it fall.
Old 10-07-2006, 10:21 PM   #4
qksilver
Re: Aux Fuel Tank
My longhorn has the fillers in the wheel wells on both sides toward the front
qksilver is offline   Reply With Quote
Old 10-07-2006, 10:28 PM   #5
bartstoy
bartstoy's Avatar
Re: Aux Fuel Tank
I had two tanks on my longbed ,one on driver side and one on passenger side. They were just behind the cab in front of rear wheels. Each had an access door and each held 17.5 gallons. They were aftermarket add ons.
Original owner '69 C20, long, fleet.
454 BB with Edelbrock stuff.
Work truck for years, 2nd restoration going on.
'69 C20
'03 Tahoe Z71
70 Hp Johnson pushing aluminum bass boat.
All things in life are uncertain, so eat dessert first.
bartstoy is offline   Reply With Quote
Old 10-07-2006, 10:31 PM   #6
superjeer
superjeer's Avatar
Re: Aux Fuel Tank
Mine has one 20 gal tank on either side. The fillers are in the wheel wells. Let me know if you need pics.
Thanks,
Jere
'72 Cheyenne LWB, Dark Olive.. gone.
Others02 Sienna XLE, 1998 Mercury Tracer Past in order of exit 04 xB RS1, 04 xB BCP, 87 Sciorrco, 97 Safari, 95 Contour, some dodge stratus, 87 Nova notchback, 87 Nova 5 door, 84 Z28. 81 C10 LWB 305
http://www.elmiradhc.com/
http://elmirahockey.com/
superjeer is offline   Reply With Quote
Old 10-07-2006, 11:25 PM   #7
rage'nrat638
rage'nrat638's Avatar
Re: Aux Fuel Tank
heres mine two 15 gal tanks
rage'nrat638 is offline   Reply With Quote
Old 10-07-2006, 11:36 PM   #8
Aarons72s
Re: Aux Fuel Tank
Here is some photos I got off the board a few years back of the tanks. I think they came off the parts board. These look like the same ones that are on my green and white. I wish they worked. Plan on reactivating them one year. Hopefully?
Aaron
Aarons72s is offline   Reply With Quote
Old 10-07-2006, 11:41 PM   #9
Texasdeere
Texasdeere's Avatar
Re: Aux Fuel Tank
Thanks a bunch guys. The truck I am looking to buy, has the valve on the floor by the drivers side of the bench seat, but no hoses or tank anywhere and no openings in the bed either. Supposedly the tank is around the shop somewhere, but I dont know what it looks like to claim it.
Old 10-07-2006, 11:45 PM   #10
Aarons72s
Re: Aux Fuel Tank
Sounds like it had the ones with the filler in the wheel well. My control valve was in the same position until I removed it. Frozen and stripped.
Aaron
Old 10-08-2006, 12:02 AM   #11
bartstoy
bartstoy's Avatar
Re: Aux Fuel Tank
Aarons72s,
Those are the same tanks I had , could not give them away, wish I had kept them. Do you think they could be adapted for floats?
bart
'69 C20
'03 Tahoe Z71
Old 10-08-2006, 12:22 AM   #12
Aarons72s
Re: Aux Fuel Tank
When i eventually drop them I plan to have holes cut in them for those universal sending units like what they sell thru lets say JC Whitney. I am pretty sure they will fit. It is just not a top priority right now. I am also plannig to install a small gauge pod for individual gauges and put in electrical tranfer valves. To me valve under seats suck! But we are talking a long way off. My dream eventually for my green and white is to have overdrive( 2004r), good running 350, all 3 fuel tanks- posibly add a fourth- the blazer tank- so I can make it from okc to Indinapolis with out stopping, ie 800 miles without refueling. I have been trying for the past 5 years to get my orange truck done. It has ate most of my money. Especially since she came from Indianna.
Aaron
Old 10-08-2006, 08:04 AM   #13
Hook'em
Hook'em's Avatar
Re: Aux Fuel Tank
I have two saddle tanks.
Hook'em
Hook'em is offline   Reply With Quote
Old 10-09-2006, 05:59 AM   #14
superjeer
superjeer's Avatar
Re: Aux Fuel Tank
hmmm.. the ones I have are black poly.
My cam. bats were dead yesterday. I'll try again today to take a pic.
Thanks,
Jere
Old 10-09-2006, 08:13 AM   #15
mrein3
mrein3's Avatar
Re: Aux Fuel Tank
Aaron
The universal fuel gauge from JC Whitney does indeed work.
I dropped my tank, emptied all the gas, filled it with water (yeah I'm a chicken) and drilled a hole in the top. I mounted the gauge that comes with it knee-knocker style under my heater controller.
It sure is nice knowing how much fuel is in there.
800 miles without stopping? That may be doable. Lets say you some how get up to 15mpg on the road with the overdrive. 800 / 15 = 53.3 gallons.
If you keep the seat tank, install a saddle tank on the drivers side, and put in a Blazer tank with the filler on the drivers side, you'd get 57 +/- gallons of capacity. That would get you there.
With a touch of a reserve.
I had a buddy with a '76 with the tanks on each side. You don't want that situation. It sucks filling the tank on the other side. Most people at gas stations aren't that patient to allow you to flip your truck around and fill the other side.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 10-09-2006, 04:23 PM   #16
Aarons72s
Re: Aux Fuel Tank
mrein3 thanks. I do have both saddle tanks- driver and passenger. The only tank mine doesent have is the blazer tank, yet. My trip of about 800 miles is esentially from okc to indinapolis. All interstate. That is where we are originally from and all are family lives back there. I would like to take the truck one day up there and I have a thing about stopping. Right now when we go back we do it in about 11 to 12 hours but that is with stopping for fuel twice and bathrooms. The one I hate stopping fo is gas, especially in illinois and around st louis. I dont use the rest rooms, I somewhat have the nickname camel on road trips but everyone else in my family has to stop constantly. And if I take the truck it will only be me. Plus if I take road trips elsewhere I know I am good to go anywhere.
Aaron
