Old 10-04-2006, 08:22 PM   #1
MNorby
MNorby's Avatar
froze body mounts
going to start installing a body lift tonight and got all the nuts off the but can't get any bolts to come out, just lift up through frame mount and the back most bolt won't even do that but a half inch up. Looks like the back 2 bolts are tack welded to the body too. Any tips? I am to the point of griding off head then airhammer down but figured would see if there is any other ways people have done it. thanks.
MNorby is offline   Reply With Quote
Old 10-04-2006, 08:54 PM   #2
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
Re: froze body mounts
just have to grind off the tack welds between the bolt and the body. probably a good bit of rust too.........may need some single jack persuasion
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 10-04-2006, 10:22 PM   #3
MNorby
MNorby's Avatar
I have the whole rig in the air with the porta power under that one bolt and I jump up in bed and still no movement.
Old 10-05-2006, 06:10 AM   #4
vtblazer
vtblazer's Avatar
Been there and have had to do it that way but use it as a last resort.
Try cleaning off the spot weld first, then go from there accordingly.
vtblazer is offline   Reply With Quote
Old 10-05-2006, 09:23 AM   #5
VinceY
Just need a couple more parts.
VinceY's Avatar
When I replaced mine, all the bolts with the exception of the two in the rad area, were tacked to the body. To make things worse the previous owner had put in a spray in liner. I used a Dremel to grind the tack welds and was able to do a very clean job that did not wreck the liner. Time consuming but worth it in the end.
1947 Studebaker M5 project to match the camping trailer.
1950 Chev 4x4 Pickup
1958 Shasta Airflyte Travel trailer (fresh restoration)
1971 C/10 Pickup(Frame off Restoration)
1972 K5 Blazer CST (Daily Driver & My Company Truck)
1976 Honda CB750 Bobber
1988 Jaguar XJ12
VinceY is offline   Reply With Quote
Old 10-05-2006, 07:48 PM   #6
MNorby
MNorby's Avatar
I messed with it a little tonight and my quesiton was, on the rear bolts that are a carriage type bolt if i grind the head of the bolt off and try to air hammer down with the square flange on the top of bolt fit down that cast in sleave/tube type deal in the main body support (Make senase)? if so I will hammer down. If not i would prob shoot myself in foot doing that and wedge the square flank part of carrage bolt in that tube deal.
Old 10-05-2006, 08:48 PM   #7
jaros44sr
jaros44sr's Avatar
Your right it may not fit thru the tube, any chance you could cut the nut off and hit it up from the bottom? Jim
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-06-2006, 08:03 AM   #8
orange72blazer
orange72blazer's Avatar
I did all of mine this way without any problems.
1972 Chevy Blazer
1997 GMC Sierra
2009 Chevy Tahoe
orange72blazer is offline   Reply With Quote
Old 10-06-2006, 07:44 PM   #9
MNorby
MNorby's Avatar
cool, thanks for the info orange72. I could prob go up with all the bolts except the veyr back ones since they are in the C of the frame and not on a bracket off the side of the frame
Old 10-07-2006, 08:09 AM   #10
jaros44sr
jaros44sr's Avatar
I just took off the last of my body bolts as I'm doing the PS floorboard, I cut the nut vertically twice and chiseled the slots I created. Looking at the area your talking about you should be able to fit the grinder w/cut off wheel in there. Problem is you won't have much room to swing a hammer. I think I read you have a port a power tool, you could press it up with that. Jim
SAFETY FIRST
AS usual, off topic
Jim
Old 10-07-2006, 08:34 AM   #11
MNorby
MNorby's Avatar
yeah, I was using the porta power on the rear most bolt. Had the back tire off the ground even pushing up on just that bolt plus jumping in bed and beating against the foot of the porta power and no luck
Old 10-07-2006, 12:09 PM   #12
jaros44sr
jaros44sr's Avatar
Torch?
SAFETY FIRST
AS usual, off topic
Jim
Old 10-07-2006, 10:37 PM   #13
MNorby
MNorby's Avatar
that was another drastic measure. Might try to heat that body tube deal to see if that helps. Am gonna try the air hammer next. Need to order body mounts. Got the engine and trans/case pulled today and almost have the drivetrain out of my truggy out to swap maybe tomarrow.
Old 11-03-2006, 12:26 PM   #14
MNorby
MNorby's Avatar
Well I got the mounts out and new ones in. Just need to find longer bolts for a few spots, Couldn't find a 13" long 3/8 bolt so got some all-thread for those 3 long ones. That is if I keep the 3" body lift. It's huge now so may cut the pucks in half.
Old 11-03-2006, 01:09 PM   #15
jaros44sr
jaros44sr's Avatar
Mc Master-Carr had the carriage bolts, I think they went up to 13", that I used. J
SAFETY FIRST
AS usual, off topic
Jim
Old 11-04-2006, 01:31 AM   #16
MNorby
MNorby's Avatar
I called all the machine shops and bolt shops and 10" was the longest. Since it is right next to that other bolt I'll just put lock nuts on each end of the all thread. I'm just using regular bolts on everything instead of carriage so won't hardly be noticeable. Then I'll bedliner then whole interior.
Old 11-04-2006, 02:15 AM   #17
Southedisto
River life......
Southedisto's Avatar
Good luck finding the long bolts, I have been looking for nearly a month.
1/2"D, 14"L with 13-20 thread, nothing. I may resort to some allthread also.
Southedisto is offline   Reply With Quote
Old 11-04-2006, 08:05 PM   #18
pound41
Home Depot had the long carriage bolts. I bought a complete set of bolts from LMC for my 70. Then I went to home depot to make a set for the 71. The only one they didn't have was the front mount in the floor pan
pound41 is offline   Reply With Quote
