Old 10-05-2006, 02:31 AM   #1
jmking9
jmking9's Avatar
Bed floor advice?
I am building a shortbed out of my old long bed, I have new bed sides, front gate, etc. My question is, whats the best way to cut the long floor down to fit a short bed? I really want to use this floor because it is in great shape. If anyone has done this or has any ideas or pics it would be very helpful. I know I need to take 12" in front of the wheels and 8" behind, but what would be the easiest way to do it. Thanks
jmking9 is offline   Reply With Quote
Old 10-05-2006, 07:27 AM   #2
arkracing
Weekend Warrior
Re: Bed floor advice?
I don't know what type of quality job your are looking for - but to do it and have it very nice - i would suggest taking the floor apart -
remove the rear cross sill and all the cross sills (by drilling out the spot welds) - then cut the two ends to the length that you need and re-install the cross sills for a shortbed.
if you try to weld al the way across the bed floor by just cutting and shortening it is going to look bad - unless you are a really good body man - and can sling mud well. the problem with that is that now you have bondo that will chip of the first time you put something in it.
I suppose you could also "Rhino Line" or "Line-X" the bed to hid the welds - but that cost $$$
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
