Old 10-05-2006, 01:28 PM   #1
jeda's71
69 c20 conversion to k20
hi folks,
can anyone give input to the difference between a 2wd and a 4wd 20 series frame? i have a 69 longhorn with rear leaf suspension and a complete 71 k20 suspension. other than the motor cross member, is there any quirks to this conversion? i am having trouble finding links for this conversion.
any help would be appreciated.
jeda's71 is offline   Reply With Quote
Old 10-05-2006, 02:07 PM   #2
67chevy2wd
67chevy2wd's Avatar
Re: 69 c20 conversion to k20
Don't quote me on this but I think the frames are shaped differently. If I remember correctly there was a thread on this awhile back and it was said to be easier to use a 4X4 frame instead of the 2wd frame or vise versa depending on which way you are going with it.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 10-06-2006, 08:48 AM   #3
jeda's71
i found a site that had the original frame specs, and the front frame hump looked taller for a 4wd. just trying to find out if all the work will be worth it.. thanks for the reply
