Old 10-05-2006, 03:41 PM   #1
jtm
jtm's Avatar
Headliner piece
ok, slowly working on the '64 i bought...willl be putting in front disc brakes and power steering within the next couple of weeks. have been grinding and sanding and have torn the worn out bed out (sort of custom replacing it for now, may get kit later depending on how bad i screw it up)...short of getting a couple of pieces of metal in my left eye, it has been fun...here is my most immediate need.
behind the visor on the driver's side is a rusted hole...actually it is a cut out hole now. I am looking for a junked 64-66 that has the headliner intact so i can cut the piece out and weld it back into place on mine...anyone know of any around where they are that are av for that?
wherever you go...there you are...
jtm is offline   Reply With Quote
Old 10-06-2006, 12:45 AM   #2
Eagar1
Re: Headliner piece
Why not just build it from scratch? Anything you cut out from an older truck will warp and take alot of work to refit anyway. the metal is double walled there, so you may as well just patch it soundly then build what ever lines you need out of bondo, or just cover it up with a custom headliner built out of masonite covered with foam and some nice material.
Eagar1 is offline   Reply With Quote
Old 10-08-2006, 08:49 PM   #3
zenish
Re: Headliner piece
another alternative is to get a vinal headliner from impala bob.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 10-14-2006, 06:04 PM   #4
jtm
jtm's Avatar
Re: Headliner piece
part of problem is hole encompasses the lip that the window gasket goes on. fabrication my be only option but have had a couple of guys here say it would be easier to cut the piece from another chevy.
i like the headliner idea. was thinking abobut trying to make one...who is impala bob?
Old 10-14-2006, 07:26 PM   #5
mbgmike
Re: Headliner piece
It Would Be Easier To Cut One From Another Year. If You Can Find Someone That Will Let You . You Should Be Able To Find One That Will If You Have The Time. Most Times They Want Us To Buy The Whole Cab
mbgmike is offline   Reply With Quote
Old 10-14-2006, 09:58 PM   #6
zenish
Re: Headliner piece
www.impalas.com their catalog shows one covered with tweed,choise of colors.website says no.might try calling/
1964 c10 short step
1962 econoline van
1989 rs camaro
1975 goldwing
Old 10-17-2006, 09:33 AM   #7
jtm
jtm's Avatar
Re: Headliner piece
thanks..i found the web site, said they did not have them for 64s, will call them
