Wheel & tire size
I have a 72 longbed 2wd, front disc brakes, lowered 3 inches in front and 4 inches in the rear and would like to know what the largest wheel/tire combination would work that does not rub or what combo size looks the best? Anyone with pics? Thanks
Re: Wheel & tire size
looks best is a matter of opinion. what do you mean by biggest combo? hieght? width? i have 20 x 8.5 rims with 275-55-20 tires that are 31 inchs tall. my front is lowered 2 1/2 inchs and has room for another easy 2 inchs. keep in mind backspacing is key for large wheels and tires. i lke the tall tire because it fills the wheel well front to back as well as top. never could understand why so many wheelwells are made so long. i dont see the balance. but its just my opinion. pkj
Thanks for the info, I also want to fill the wheel opening, what size backspacing are you using? The local tire shops don't seem to know much on a 72 and i'm kinda in the dark also.
![]() Join Date: Aug 2006
I just purchased 20x8.5 for the front and 20x10 for the rear. I am going to be running a low pro tires but the sizes are 245/35/20 and 275/30/20. My back spacing is 4" for the front and 4.5" for the rear. I am supposed to not have any rubbing or modifications to make them work. I will know soon. Good Luck. Josh
#5 | |
Good luck! http://67-72chevytrucks.com/vboard/s...d.php?t=210041
78 C10 LWB Super Cheyenne |
I have 285 35 22's on 9.5 in wheels w/ 6 inches of backspacing. The tires are roughly 30x11 inches. I have a 2/4 drop and the fronts fit good, for some reason the rears tuck in about 1 1/2 in. more than the front so ill need spacers to even them out. Im also considered going with a 305 40 cuz im a little nervous about overloading my low profile tires but I dont know if it will be too wide.
braggwood i am using the 07 tahoe 20 inch wheel. my backspacing was 5 1/2 inchs. i used 2 inch adapters on rear that gave me 3 1/2 inch rear backspace. on front i used 1 1/4 inch adapters that gave me 3 1/2 inch front backspacing. mt truck is a 68 and i understand the rearend is 3/4 of an inch narrower then other years (somebody please chime in on this) anyways the tires sit square each fender hangs over tire same amount. pkj
Keepin an eye out
For more reference: 15x8.5", 3.75" back space. 255-60 front 275-60 rear tires. 3-5 drop, no rubbing-no bumping.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
