Old 10-06-2006, 06:09 PM   #1
braggwood
Will the paint stick?
I have a 72 chrome grille shell that has tarnished, I want to paint it the same color as the truck, is there anything I should do other than sand, to make paint stick. I also plan to do the same on chrome door handles and mirrors which are pitted and need sanded. ALL ONE COLOR!! Thanks
braggwood is offline   Reply With Quote
Old 10-06-2006, 06:12 PM   #2
68GenIII
Re: Will the paint stick?
You could probably sand blast them to ruff em up?
68 lwb to swb Cummins swap in the works. I promise it will be cool someday.
68GenIII is offline   Reply With Quote
Old 10-06-2006, 06:35 PM   #3
cableguy0
use a good etching primer so it bonds well to the grill shell.just painting it its most likely going to flake off. i would also sand it pretty good
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-06-2006, 07:06 PM   #4
CPNEJR
CPNEJR's Avatar
sand it with a course sand paper and use self etching primer so that it will adhere to it and then paint
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 10-06-2006, 07:20 PM   #5
72-stomper
Are you sure your grill is chrome and not aoidizied aluminum????? Better make sure....And I would use a 2k epoxy primer instead if the self etch...I am not sure if the "old school" etch primer can be sprayed on aluminun like epoxy.(ppg dplf).....I would LIGHTLY sand blast to roughen up the surface....
Lightly means just enough to dull up the surface....No more....Lightly....
Epoxy sticks to anything.......
72-stomper is offline   Reply With Quote
Old 10-06-2006, 08:22 PM   #6
CMars45000
CMars45000's Avatar
An etch wash or primer is not really necessary since corrosion on aluminum is not a HUGE issue (Yes, bare aluminum will oxidize a little but not to the extent that bare steel will..) I would just sand blast it and then use a high build 2k primer and sand with P600 and then base and clear it... Epoxy primer will work well too just lay it down flat b/c it is nasty to sand ...
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 10-06-2006, 09:04 PM   #7
Aarons72s
Etch prime it. I worked for a company for a couple of days that painted aluminum box trucks for oil fields. They acid primed the shell then coated it with single stage nason paint. Looked nice and from what the guy told me that was how they do all the aluminum bodied vehicles. The acid prime is not for corrosian at least in this case it just gives the paint something really good to bond to thanks to the primer etches itself into the metal.
Aaron
Aarons72s is offline   Reply With Quote
Old 10-07-2006, 11:42 PM   #8
bigbassmann
bigbassmann's Avatar
I sanded the grill shell on my '70 C10 with 100 grit sandpaper. I also did a little body work (knocking out dents, dings and bent areas) and used some body filler to smooth everything out. Primed and then painted with Nason bc/cc. Turned out real nice.
bigbassmann is offline   Reply With Quote
Old 10-08-2006, 03:42 PM   #9
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
All GMC grills are steel.
Sand blast it. That is the best way to get all of the surfaces and edges roughed up, including the back. It removes rust better than sanding, also.
Treat it like bare metal: etch or self-etch.
PICKMUP is offline   Reply With Quote
